1 threads found!
Omnedon | 8 | 228 |
34 comments found!
Thread: Michael wont render | Forum: Poser Technical
What machine are you running? How much mem, how fast, etc... Can you render other scenes with mutiple figures (other than Michael). What about Michael with props and/or background?
Thread: modeling and textures | Forum: Poser - OFFICIAL
Attached Link: http://www.cakeone.com
There is a tutorial here for the texturing aspect of making a 'self-portrait'.Thread: Urban/City Environments | Forum: Poser - OFFICIAL
Joined as blackomne99 grins This is one of the things that has been "upcoming" on the project list (need characters and the city for them to run around in, not sure which to do first...)
Thread: DAZ 3D and The Tailor, Please clarify your position | Forum: Poser - OFFICIAL
Ahh... So it does put morphs into the clothing item... Is it possible, if I were to take V2, set the morphs as desired (for example I twiddle V2 for a character and call her 'Anne') to use (Morph Manager, Objaction Mover?) to lock the morphs. Then run Tailor and make clothes for Anne. So... I know it is possible to distribute alterations (require V2 and add my alterations to make Anne) but my alterations without V2 would be useless. And clothes for Anne would not fit V2... (Although I suppose the clothes for Anne could then be used to make V2 into Anne without actually having the alterations.) Or am I just getting more confused?
Umm... A question. DAZ is against distribution of anything that could be worked back to 'create' one of their products. That is reasonable. So... If I have V2 and Tailor, and I make an item for V2, is it possible to re-create V2 from that item of clothing? It seems to me more like Tailor would 'fit' an item to a figure with morphs set at a speciphic point. Would the clothing adapt if I later changed the morph settings, or would I have to run Tailor again?
Thread: I need HELP!!! | Forum: Poser Technical
Hopefully someone will be able to point you to something that will work. Unfortunately the only thing you can do if you can't find something pre-made, is to make it yourself. Good luck!
Thread: Poser to Photoshop | Forum: Poser Technical
I think Poser can do .bmp and/or .tif, which should be readable without loss of clarity. .jpg should only used for final output (for web publishing) as each time a .jpg is re-saved, data is lost.
Thread: Getting clothing to fit my models??? | Forum: Poser Technical
http://www.renderosity.com/tutlink.ez?tutorialid=426 http://www.renderosity.com/tutlink.ez?tutorialid=358 http://www.renderosity.com/tutlink.ez?tutorialid=219 Go to tutorials at the top of the page, then search, enter "conform" into the box. You will get about 8 items, the 3 above appear to be good places to start...
Thread: What am I missing? (Transparency ?) | Forum: Poser Technical
Ok, I imported azalea as background and used the transmap above on a square and it rendered as ...
So it works there, but I am doing the same things and it refuses to work in other projects... Here I could tell that it worked as soon as I ckicked OK in Materials...
Thread: Cant upload image | Forum: Community Center
Thread: Mixing Fractal Applications for Ssome Fascinating Effects | Forum: Fractals
audre, this company does vinyl wraps for cars, primarily for advertising, but they can do custom graphics (see the FAQ link). http://www.drivefreesigns.com/cgi-bin/d.cgi/1000/index.html
Thread: Renderosity password | Forum: Community Center
No emails here (yet), then again, I haven't purchased from the store either. If one were to be paranoid, one might wonder how the 'hacker' (if such is doing this) is selecting suitable targets...
Thread: Awesome New Environment Prop | Forum: MarketPlace Showcase
