We couldn't find any threads matching the specified search criteria.
10 comments found!
Peggy
Quote - That's the problem - the code is not the same - windowsXP64 was the beta for Vista. Saying things worked great in 64 but don't work in Vista is useless.
I agree, and even worse, Vista is the beta for a stable OS in the future. Maybe after the 2nd Service Pack. I think almost a third of the Vista code is new. And partly erratic, as every new piece of software. For other 3d Applications, like 3ds max, Vista is not one of the supported OS now.
Quote - I have faith that e-on will make it work. Vue 4 was great, Vue 5 Infinite was awesome, I love Vue 6 Infinite even more. I will willingly buy version 7 and go through this whole process again.
I totally agree as well.
Compared to 3ds max (I payed about $5000 for plus environmental plugins), VUE, although it still has a few errors, is really great.
My max9 installations are crashing every now and then, VUE6 only once a day. Be positive! ;-)
Read the Autodesk max9 (10 times as expensive) newsgroup and you will hear the same protest songs as here.
New Software is erratic. Thats a fact of life. If one can't accept it, he shouldn't buy it (brand new).
peace ;-)
Thread: If any of us post anything positive about Vue or E-on are we always going to get | Forum: Vue
it's not a bug, ist's a feature :-)
Just click the little "ghost" icon in the in the material- or atmosphere browser and you'll never see the cornucopia content again.
easy enough :-)
But the best thing was when i opened up the new materials and thought like "Ah, paint - cool that they added this" and you select the material and it asks you to buy the materials from cornucopia now. THATS REALLY NASTY! Eon you mean old men, if you dont wanna include a material, then leave it out. I dont pay over 200 bucks for a software that always tells me like "Buy this now, buy that then". This is how these ringtone companies rip off teenagers, but no professional business behaviour. AT LEAST ONE DAMN MATERIAL SHOULD HAVE BEEN INCLUDED IN THAT CATEGORY. Then i could maybe have forgiven eon.
Funny. I don't encounter major problems with VUE inf. No memory leaks, no crashes.
The VUE XStream in conjunction with 3ds max causes more problems and max crashes every now and then. But max crashes every now and then wether you use VUE or any other given plugin... ;-)
I've been application programmer for some years and I know, how hard it is, to program a software, that is mainly errorfree. Impossible? To be honest, we never published one, that was without known issues. Problem is, that an application running on one PC must not on another.
Problems depend on a lot of circumstances, like hardware and Operating system constellation as well as on other installed programs or packages.
Thats why software producers need us paying customers as beta-testers. :-)
Thread: Does Vue do real time renders ? | Forum: Vue
of course VUE has no realtime rendering capabilities. It was never intended for.
For most of the scenes, VUE IS intended for, this will be true for the next decades, because, even if computer speed doubles every year, it takes 17 years until VUE would be able to render a film (25/30 fps) in realtime, when a single frame renders one hour today.
3ds max, for instance, doesn't have realtime render capabilities either, but, with a plugin (RTRE) , you can get realtime renders in a kind of preview(low, low) quality.
Thread: SideBySide errors found in system event viewer | Forum: Vue
Aldaron,
the side by side error is not a unique one, but a class of errors. The more important information follows the SBS error. Paste the error description and the name of the scene here, perhaps we can see what is causing it.
btw, did you install the update for VUE Inf 6 ?
regards,
Roger
Here's VC++ redist X64 link
http://www.microsoft.com/downloads/details.aspx?FamilyID=90548130-4468-4bbc-9673-d6acabd5d13b&DisplayLang=en
I've attached the redist file as a .zip
I hope that works.
regards,
Roger
No, didn't work. Had to search ms-download. Here's the link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=32bc1bee-a3f9-4c13-9c99-220b62a191ee&DisplayLang=en
It's newer than the one, I used but I think that does not matter.
So I'll try the C++ v8 redist pack and see.
If that doesn't work, here's a description to fix the problem manually:
Though there are no runtime errors,there might be errors in event viewer** like Component identity found in manifest does not match the identity of the component requested Syntax error in manifest or policy file
"C:ClientMicrosoft.VC80.MFC.MANIFEST" on line 4. Generate Activation.Context failed for C:Clienttest.dll. Reference error message: The operation completed successfully
There are 2 bugs which cause this.
Solution
Change the version number
should be changed to
Quote - ... Is this some kind of new check your computer activity by MS?
No, this portion of SBS is written by Seagate. The purpose is filling the harddisk ;-)
SidesBySide is part of the Microsoft Visual Studio development tools for C++ (and perhaps the other programming languages as well).
I once encountered a lot of SBS errors saying SBS was'nt correctly installed. Some progs did'nt react after starting and all my application log was full.
After I installed the C++ V8 redist package (you can obtain it from MS download), I do'nt have problems any more.
