2 threads found!
SEJ | 3 | 125 | ||
SEJ | 5 | 140 |
5 comments found!
If all this mess has taught me is to NEVER preorder software again. NEVER! I am not so much disappointed with the DAZ aquisition of Eovia because it seems to been the trend for software companies now, Autodesk/Maya, Adobe/Macromedia, eFrontier/Curious Labs (you cannot count on any company to stick around anymore).
I am very disappointed Hexagon 2 was released so darn many bugs. It seems very half-baked to me.
Thread: Strange lines in Hexagon display | Forum: Carrara
Thread: The dust is starting to settle. | Forum: Carrara
I agree, I hope DAZ does fine.
The test will be is to see how DAZ handles the bugs and future versions of Hexagon and Carrara.
Thread: UV Unfold bug found... | Forum: Carrara
Yeah, I flipped the bad displacement map in the Carrara file (the displacement map was exported from Hexagon 2) and the displacement map was still bad though the texture map was good. Go figure? (seems half-baked)
In the object file the displacement was flattened by nature of the file (as it states in the manual it becomes part of the object file). So the displacement always comes in good in an object file. The texture map, however, in the object file comes in very screwed up. I also tried flipping the object file's texture map to make it work. The texture map would just move around the object differently always showing large breaks and the base white color of the object.
Not good results either way using UV Unfold.
Thread: Hexagon UV Unfold tool questions? | Forum: Carrara
Well I got UV Unfold UVs to work inside Carrara by exporting from Hex 2 as a Carrara file. However the exported displacement map was a mess when applied in Carrara.
When exported as an object file the displacement is good and the UV texture is a mess.
Thread: So much for being an early adopter of hex 2 | Forum: Carrara
