7 threads found!
Sesh | 0 | 19 |
(none)
Sesh | 1 | 96 | ||
Sesh | 4 | 20 | ||
Sesh | 11 | 39 | ||
Sesh | 12 | 44 | ||
Sesh | 4 | 21 | ||
Sesh | 7 | 29 |
23 comments found!
Are they coming out with exterior texture maps with liveries (? spelling) of the major airlines or would this be a niche for texture specialists?
Thread: Kodak DC4800 users feedback please | Forum: Photography
Thread: Text to Voice Conversion | Forum: Poser - OFFICIAL
Attached Link: http://www.glyphscribe.com/Nofret/
Sorry the link is case sensitive. Corrected link.Thread: Text to Voice Conversion | Forum: Poser - OFFICIAL
Attached Link: http://www.glyphscribe.com/nofret/
Check out my site at the attached link. You have to download some components (all standard Microsoft text to speech stuff) but once you do that, Nofret will speak the text you type (unfortunately this is for Egyptian hieroglyphs but there are some phrases you can cut and paste into the text box at the site. There are controls where you can adjust the pitch, speed, and reveberation. This is all done using HTML scripting and an Active-X text to speech component plus the text-to-speech engine you download.Thread: vendor dropdown list for MarketPlace | Forum: Community Center
Thread: Help in Prop Creation - removing motion control | Forum: Poser - OFFICIAL
One way is to use a text editor to edit your CR2 file. If you look at your CR2 under each of your groups you will find a list of "channels" which correspond to the dials. There will be a parameter "hidden" which is normally 0 to show the dial. You will have to change it to a 1. Do back up your CR2 first. Hope this helps.
Thread: Vue2 | Forum: Vue
For all its worth, I installed Vue2 without a registration # on my older computer and tried updating it to 2.1 and couldn't. My guess is that one of the modules in the upgrade checks for a valid registration # (see my previous post). Sesh
Attached Link: http://www.e-onsoftware.com/OnlineReg/Vue2/ComputerArts55.phtml
Also just got Vue2 from the Computer Arts CD. You have to register before you install and they will E-Mail you a registration code which you enter when you install, upgrading it to 2.1. Looks like you have a lively group here mjustmike. SeshThread: Help -- importing OBJ groups into Poser 4 | Forum: Poser - OFFICIAL
Very impressive list of accomplishments Anthony. I have dabbled in C++ programming even if I hate to type, see the attached link.Thread: Help -- importing OBJ groups into Poser 4 | Forum: Poser - OFFICIAL
Anthony, I use the .phi method if there is a .phi file I can use as a template (I hate to type). For a non-standard hierachy, just using your mouse to arrange things in the hierachy editor sure saves the typing.
After selecting the figure, hit the grouping tool button, then click on spawn props. The figure should seperate into its parts. You can then delete the original mesh. That's what I do when I create a mesh in C4D and bring it into Poser to adjust the joints.
Thread: Poser and Painter3d question. | Forum: Poser Technical
Try the acquire menu item in lieu of import. the first xx = .3mf, 2nd xx = .3ds, 3rd xx = .dxf and 4th xx = .obj
Thread: Need a Normal Flipper Utility | Forum: Poser Technical
Anthony, your message must have come in while I was composing mine. Thanks for the enlightenment on the vn lines and rotation order of the vertices in a face. I guess I just want to do the latter although using the reverse normal options in Poser seem to have the same effect.
Thread: New Pictures and more info on the 737 project. | Forum: Poser - OFFICIAL
