51 threads found!
SickenlySweete | 1 | 102 | ||
SickenlySweete | 0 | 135 |
(none)
SickenlySweete | 1 | 89 | ||
SickenlySweete | 3 | 165 | ||
SickenlySweete | 2 | 69 | ||
SickenlySweete | 5 | 191 | ||
SickenlySweete | 31 | 1629 | ||
SickenlySweete | 7 | 450 | ||
SickenlySweete | 5 | 148 | ||
SickenlySweete | 7 | 211 | ||
SickenlySweete | 7 | 124 | ||
SickenlySweete | 0 | 40 |
(none)
SickenlySweete | 20 | 372 | ||
SickenlySweete | 7 | 306 | ||
SickenlySweete | 1 | 82 |
440 comments found!
Yes thats a uv map problem not a studio one.
Hedus uvlayout works great.
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
Thread: Genesis 1 | Forum: DAZ|Studio
Come the first of the yr, i will be one vendor that will be supporting genesis 1 exclusively.
Thread: Startup path issues | Forum: DAZ|Studio
Reinstall genesis and it will fix this
Thread: I'm looking for help with DS3 | Forum: DAZ|Studio
Move all your folders labeled content to the one main one. And merge.
You should have a set up some thing like this
My documents/daz3/my library/content/inside content should be one of each, data, runtime, people, shaders, scenes, ect.
Hope this helps.
Thread: Rendering/Shaders(?) | Forum: DAZ|Studio
Go to lips in the surface tab and play with the glossy setting and the spectral one.
Thread: Moving from poser to DS, some questions to start | Forum: DAZ|Studio
The very old charaters v1-2 work, but mikes alternate hips have problems.
The old ds scene files wont open in the new ds.
You will need to recreate them.
Thread: Morph question | Forum: DAZ|Studio
Are these morphs for which characters?
Genesis morphs go into the data folder and only show up under genesis' s shape tab.
The do not show up in a content folder.
Thread: PNG Files in DAZ | Forum: DAZ|Studio
create a new primitive plane
and apply the png file
you may need to also create a transmap for it in any free paint program,
unless it also came with a black and white image to match the color version then this can be used in the opacity
i do this with fire, smoke, fog and fairy sparkles all the time.
Thread: Exporting trouble | Forum: DAZ|Studio
Did you read the readme for install and what folder it will show up in?
Try folder view instead of snmart content it may noy have metadata.
Thread: Hair & Beard | Forum: DAZ|Studio
Daz store has these two, youll have to do a search. Michael 3 Long Beard Michael's Morphing Fantasy Beard w/Hair
Thread: what situation need rig | Forum: DAZ|Studio
If the obj is needed to move/pose be it a character or clothes it needs to be rigged.
Thread: issue with making goggles | Forum: DAZ|Studio
something like that would be more likely created as a prop instead of conforming.
did you try the transfer active morphs to the googles?
also if i remembr correctly somewhere theres a place to select the eyes yellow pieces and tell studio there ridgit/hard and do not move or change with the figure.
Thread: Daz Studio Render | Forum: DAZ|Studio
You can get them logos here
Post15 attachments has the pngs just click and save
http://www.daz3d.com/forums/viewthread/3874/
Thread: Strange issue with external Run time on Mac | Forum: DAZ|Studio
Ok there not showing up where?
Poser content will not show up in the smart content library.
Only in the manual content tree view library.
Please show us a screen shot of where there not showing up please.
The poser path in the image above is incorrect.
Select that same path but, go deeper until youve actually selected the runtime folder.
Then it will show up in the library content tree.
Thread: uvmap always bend | Forum: DAZ|Studio
