93 threads found!
VolcanicMink | 4 | 443 | ||
VolcanicMink | 14 | 494 | ||
VolcanicMink | 2 | 147 | ||
VolcanicMink | 2 | 164 | ||
VolcanicMink | 12 | 979 | ||
VolcanicMink | 4 | 270 | ||
VolcanicMink | 5 | 152 | ||
VolcanicMink | 3 | 164 | ||
VolcanicMink | 4 | 137 | ||
VolcanicMink | 14 | 417 | ||
VolcanicMink | 9 | 342 | ||
VolcanicMink | 15 | 410 | ||
VolcanicMink | 2 | 304 | ||
VolcanicMink | 5 | 192 | ||
VolcanicMink | 0 | 174 |
(none)
181 comments found!
Thank you both. It did not appear to be the vertices he was selecting and that threw me off, but I'm back on track now.
Thread: 2 versions of Blender on one PC | Forum: Blender
Thread: "Select Content Location" | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Blend between lips and face | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
The only way I've found to do that so far is in Photoshop with The Smudge tool. Not very helpful advice as far as Poser goes, but thought I'd put it out there:)
Thread: PoserPro11 unavailable? | Forum: Poser - OFFICIAL
Thread: Proportional Editing circle | Forum: Blender
Thread: Constrain group in Blender for Poser | Forum: Blender
Ok, I'm lost again. I switched to Blender from Silo 3D, where all I had to do was export the obj file from Silo and import to Poser. I didn't need any special software or addons to make the transfer. If I import something like a t-shirt or tunic that doesn't require a constrain group it works fine. I just can't make separate vertex groups that Poser recognizes.
Thread: Making a waistband Poser will recognize | Forum: Blender
I guess I'm doing something wrong in setting the poly group. (I'm trying to make the break from Silo 3D, which I found much more straight forward.) Groups are made in the Object Data Properties panel, yes?
(Too quick on the Enter key)
How do you define (in Blender) a separate area that Poser can recognize as a Constrain group in the cloth room?
Thread: Strand hair renders blue | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
That sounds like the closest possibility so far. One thing I did find is that the hierarchy looks different in the export window than the parenting window, and re-parenting the hair groups is not fixing it. It's almost 3 a.m. here, so I'm off tonight. Try again tomorrow. Thank you!
I changed the texture to one from Biscuits that worked well on an M4 figure, and got the very same result. I have seen it suggested to turn off Branched Path Tracing, but only made it grainy.
Yeah, I've changed them all. Even tried other textures, then changed them back. I am so frustrated.
Thread: "grab curvature" How? | Forum: Blender
