23 threads found!
Whichway | 1 | 881 | ||
Whichway | 4 | 294 | ||
Whichway | 7 | 180 | ||
Whichway | 5 | 149 | ||
Whichway | 3 | 128 | ||
Whichway | 3 | 190 | ||
Whichway | 2 | 138 | ||
Whichway | 8 | 238 | ||
Whichway | 5 | 209 | ||
Whichway | 11 | 329 | ||
Whichway | 8 | 187 | ||
Whichway | 8 | 201 | ||
Whichway | 5 | 282 | ||
Whichway | 6 | 197 | ||
Whichway | 8 | 449 |
241 comments found!
Quote - > Quote - Rightio. But suppose I want to set my focal length to something close to the human eye, 100mm, for example?
I'll have to take some photos out of my window when there are some interesting clouds, just to show you what I mean. I know, a picture is worth a thousand words and all that.
The human eye is 50 mm. And Poser's focal length is wrong by a factor of 1.4. To accomplish a human eye type of field of view, you want 50 / 1.4 = 35 HAHAHAH.
Just stumbled across this. Where does the sqrt(2) come into it? I.e., what is the source of the error?
Whichway
Thread: Hair Density units? | Forum: Poser - OFFICIAL
Turns out with some experiments and a look into the geometry files, the density is in grown hairs per square display unit, independent of the polygon density. So, if your Preferences set the display units to feet, it's hairs per square foot; centimeters, then hairs per square centimeter. What is actually stored in the file is hairs per square Poser Unit, i.e., per (8.6 feet)**2. Rather a lot, usually. [17,000,000 for average human hair.] The total number of hairs value is correctly given and is the density multiplied by the area of the hair group, which, unfortunately, is not shown in the UI, but is contained in the file in square Poser Units, however, it does not include guide hairs, only grown hairs, so the actual number of hairs is larger. For a fine mesh and low hair density, the guide hairs can actually overwhelm the grown hairs. [Been there, done that.] At least that part of the Hair Room now makes sense to me.
Whichway
P.S. - If you change the Preferences display units on the fly, you probably have to at least close the document and reopen it to get the density calculation updated.
Thread: Using Blender nodes for body hair | Forum: Poser - OFFICIAL
I'm dropping this here just because I had a mail session with Anatis (@DAZ, Silke here, I'd guess) about it and she(?) pointed me here. I've not read the thread yet so apologies on that score, and this was one of my earliest experiments in the Material Room so some things are a little funky.
Render is here:
http://forum.daz3d.com/viewtopic.php?p=1719732#1719732
Screen shot of a material is here:
http://harpsichordyet.com/gallery2/main.php/v/Misc/Hairy+Material.jpg.html
Whichway
Thread: VSS and Custom Gamma value? | Forum: Poser - OFFICIAL
However, if I save out a Material Set with the changed GC values, they remain set to the value I picked when reapplied in another Poser Pro invocation. So, if I sort out my workflow properly, it shouldn't be too bad.
Whichway
Hmm. Ok, thanks guys. Setting the GC value by hand before applying the VSS Prop is what I've been doing, but was looking for an automated way. Maybe Bagginsbill knows off the top of his head if the file property table is preserved across invocationns of Poser Pro; Then I'd only have to set it up once in the lifetime of the file. If he doesn't know, I suppose I could force myself to check.
Whichway
P.S. - I checked and the table is not preserved across invocations. Not surprising, I suppose, but it means I have to fiddle the GC value once each time I use the file in any Poser Pro session. sigh
Thread: Disable auto-enable of IK on load? | Forum: Poser - OFFICIAL
Oooo - thanks PhilC. I'd tried editing them to off in the CR2 files, but didn't know to change the names. Too late to do tonight (aka this morning) but will give it a try later.
Whichway
Thread: Poser Pro 2010 beta - list of known bugs | Forum: Poser - OFFICIAL
bagginsbill - So, what shader are you using on the bathroom? Glossy? Blinn? Are you using IDL? Could you post some renders, please?
Whichway
Thread: Tutorial Scene - Poser 8 Soft Studio Lights with IDL | Forum: Poser - OFFICIAL
mariner - Yep, same version of matmatic works fine in both Poser 8 and Poser Pro 2010 beta.
Whichway
I'm glad to hear that something is happening with Poser Pro 2010. I've been using the beta for some time now, but there hasn't been a peep out of SmithMicro about it nor any way to feedback impressions short of bug reports (and no way to see outstanding issues other than my own, as far as I can tell.) Mind you, it's working quite well for me so far.
Whichway
Actually, I lost track of the VSS version numbers. I was working from VSS pr3. That was the template material set I started from. I think I like my eye shader better; at least I can justify it to myself better. Basically, I modeled the surface of the eye as covered by a film of water, so I used a form of Fresnel reflection off the EyeSurface with some Glossy folded in. I used a transparency mask so that the transmitted part of the light over the sclera passes straight through to the sclera's color map underneath. Over the cornea, the light refracts through a transparent cornea down to the iris. Tear is basically a fresnel node with glossy added so the direct lights show up. Lacrimal is the same as skin, but with glossy added. For the sclera, I used the straight colormap. It looked to me as though the VSS pr3 Template Eyewhite was practically the same as the Template Skin in VSS pr2. Since the sclera is such a different tissue from skin, things like SSS, bumps, etc. probably don't apply. Anyway, that was my thinking.
Whichway
Whichway
I will look into the details of VSS3 next.
Whichway
Whichway
Thread: Lets talk about skies | Forum: Poser - OFFICIAL
