80 threads found!
ajmarti | 18 | 532 | ||
ajmarti | 16 | 621 | ||
ajmarti | 8 | 345 | ||
ajmarti | 6 | 281 | ||
ajmarti | 18 | 3501 | ||
ajmarti | 2 | 184 | ||
ajmarti | 2 | 446 | ||
ajmarti | 2 | 280 | ||
ajmarti | 3 | 229 | ||
ajmarti | 12 | 382 | ||
ajmarti | 4 | 129 | ||
ajmarti | 17 | 386 | ||
ajmarti | 5 | 229 | ||
ajmarti | 2 | 48 | ||
ajmarti | 4 | 216 |
215 comments found!
Excellent!!!! Thank you so much! I really appreciate it!ÂFor example, Caisson has a complete thread only on PrincipledBSDF. Using Poser13, you will find new options and possibilities added to the node, but reading this thread, you'll get a huge idea of what's possible:
https://www.renderosity.com/forums/threads/2954649/principled-bsdf-some-examples
Artist @ajmarti.com
Thread: HELP lease! Render problem | Forum: Poser 13
There are several forum threads dealing with optimizing material shaders for Superfly rendering. Although some of the older content with simplified node arrangements might render well in Superfly, there are significant changes that need to be made to truly create physically based rendering (PBR). In essence, you get rid of all the hacks that were invented in earlier versions of Poser and render images with realistic responses to its 3D environment. There are some tutorials available, but I would need to do a deep dive to find some good ones. If you proceed as far as using Cycles in Poser, then there are many Blender YouTube tutorials available that can give you an introduction.I really appreciate your help! Thanks!
Artist @ajmarti.com
Ohh!.... Ok.. thank you so much!!Someone on a Mac should be able to advise you on how to update your graphics driver for your AMD Radeon. I'm on a PC so can't help there, but you probably have to do that because streaking like that may be a sign of outdated drivers.
Artist @ajmarti.com
Yes. I'm stuck with Firefly. for now.... How do I do that? Is there any tutorial available por optimizing for Superfly? I'm almost abandon Poser for Daz but I love Poser! :( I just miss getting the good old content! Thanks you so much!
Artist @ajmarti.com
hborre posted at 8:56 AM Tue, 21 May 2024 - #4485094
hi! Ok...  Firefly. I think Superbly takes too much time. On the other hand check this image attached. It says CPU. Is that correct? Should I try Superly?  Most of my Poser content is old. V4 & M4. Im working on my graphic novel and all my characters are already design with old models.GPU or CPU? Superfly or Firefly?
Artist @ajmarti.com
Randomly. After a few renders starts doing that on different parts of my final render. If I render again maybe does not happens. Or I have restart Poser 13 but again it repeats after a few rendersis this happening with different scenes or just the one scene?
Artist @ajmarti.com
Oh... I have no idea!>... Not an expert on tech things! But it's a AMD Radeon Pro 5700 XT 16 GB- 3.8 Ghz 8-Core Intel Core
Artist @ajmarti.com
Thread: HELP deciding POSER 12 or POSER 11? | Forum: Poser - OFFICIAL
RedPhantom posted at 11:08AM Tue, 17 August 2021 - #4425223
There is a list of some changes on the purchase page here
These are some changes that might not be listed there
Removal of combine figure, find unseen polygons and reduce poligons, Path Palette from figure menu
Removal of Path Palette from object menu
Removal of path palette, keyframe category list from windows menu
Update python to version 3
Remove links to websites from help menu, many of which are now closed
Faster superfly renders
Updated cycles render engine
Added denoiser
Added adaptive sampling to superfly
Added post effects to superfly
Added choice to render over background image or transparent background
Simple tab in materials room changed to assign tab. It allows you to add an mt5 material file to multiple material groups at once.
Option when switching an image in the image node, the image texture node in cycles, or the environment texture node to change the same image for all instances of the image in that material group, any material for that figure, or for the entire scene.
Updated nodes for updated cycles.
Added principled bsdf and prinsipledhair bsdf nodes
Improved search function in library
Search Renderosity and Posersoftware stores from library
Purchases tab includes content and purchases from Posersoftware as well as Renderosity marketplace. It is not required to use this, but it is available.
Some of these might be duplicates of the market place listing. I didn't compare my list with it too closely.
As randym77 said, there is a 21 day trail you can chack it out and see if the changes are for you.
THANK YOU !!
Artist @ajmarti.com
I have Big Sur... I think I'll stay with Poser 11 for a while. I don't need Superfly. Besides, it's too slow for me THANK YOU SO MUCH for your help GUYS!!!!
Artist @ajmarti.com
Thank you so much Randym77! I really appreciate your help! Yes, your observations are enough... I think ill stay with 11 for a while
Artist @ajmarti.com
Thread: Help! Again!!! | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Ummm honestly dont know..Im not very good working with nodes! Sorry! Its a set of lights very cool one I got here a few years ago but I love the results, except for that. I've chenged the main light with AO. Not sure of it could be the a skin texture problem.
hborre posted at 9:33PM Mon, 26 October 2020 - #4402237
Do you have an AO node setup with the skin texture?
Artist @ajmarti.com
Thread: HELP on this! Please! | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
