1 threads found!
akanekage | 12 | 194 |
7 comments found!
For some reason, when I try to save Props with animated poses it has never worked. However, it is most likely moot, as in the P4 scene, the sword has no real inherent motion of it's own as it is parented to the right hand, and moves with the hand. I will probably try to keyframe the sword next, and see if that has any effect...but the flames losing their motion as well is really disturbing me, as they are loaded with keyframes to get them to spread down the blade, and flicker (hense all the waves and magnets). I did spend some time setting this up when I was using the Poser 4 Pro Pack and really do not want to have to go through that ll again. I decided to ask in these forums as the help I received from Tech support was no help at all (they essentially told me to recreate the scene from the ground up in poser 7).
Thread: Poser 7 props problem | Forum: Poser - OFFICIAL
Ok, I'll grab those later tonight when that machine is free again...I'll also grab a screen from P7 preview of the same file showing where the props are not interacting how they should. I'll post those as soon as I can.
A pic of the hiarchy window or just of the overall setup? either way I can get one by later tonight, I have that machine rendering a lightwave scene right now.
When I said imported I simply meant loaded, as it is not the same version of poser it was created in I refered to it as importing(old habit). It's not a universal problem, as I do have other scenes with props that work just fine when I bring them into poser 7. It seems I have had nothing but bad luck with poser from version 4 onward. I always get strange behavior of some sort...with poser 4 it was the rendering engine causing bizarre artifacts all the time.
