We couldn't find any threads matching the specified search criteria.
6 comments found!
okay, i've submitted a new zip file with the correct folder and file paths for Toru.
Daz studio files start in a Content folder, Poser files start in a Runtime folder.
Until Renderosity allows separate Poser and DS zips, (texture files folder would need to be duplicated), the updated zip file includes install folders for both programs.
If it matters, I found the file path info in Daz3d's Q&A section:
"DAZ Studio files:
If you do get DAZ Studio format items you can put most of the files where you like (keeping the PNG file, which is the thumbnail that shows up in the Content palette, with the data file of the same name). If there's a Data folder included that has to go directly in a folder you have selected as a DAZ Studio content directory (eg if you have just the default folder it has to go in StudioContent, giving StudioContentDatawhatever subfolder it holds). The same is true if there's a Runtime folder. "
Thread: Wrong Paths in Zips getting past testers | Forum: MarketPlace Customers
tcombs, thank you for all the info. I spend thousands of dollars a year on these products and when something doesn't work properly, I just don't use it. I figured it was just something i was doing wrong, but it sounds like this is a larger, ongoing problem!
I'm working on fixing everything, it'll take me a day or two to triple check that everything is working properly.
thank you so much for pointing out all the problems. If you still want a refund, I can approve one for you.
I just bought a product made for Daz Studio that starts with" Daz/content ", which will only put a folder in Studio called "Daz".
Daz studio normally loads into: C:>Program Files>DAZ>Studio>Content
sorry for another post, i'm just trying to make sense of everything. I've scoured daz3d's site, trying to find correct path installation, and the only thing i've found says
"All files must be .zipped up in the proper folder structure. Poser files must be nestled in the Runtime... format while DAZ|Studio files must be in the content... structure. Products may be rejected if the files are not in the proper folder structure."
...which is what i've done with my products. Since you can manually put the folders where they need to go , and the correct paths are listed in the readme file, I don't understand the problem.
my daz program does not have any content in the path that you mentioned above.
everything that i have installed from daz goes through the path:
C:>Program Files>DAZ>content
is this wrong?
also, renderosity only allows 3 zip files max, which is why the daz content folders and poser runtime folders are included in the same zips. The readme.txt shows proper paths for installation.
i guess i will look for daz tutorials on the proper way to save characters with correct paths?
hey guys, i was just directed to this thread....I've been down with the flu so i haven't replied to any emails lately.
i'm still new at product making and path creation, I was hoping that the people who tested my product would give me any heads up, but it looks like we're both still learning.
there shouldn't be any poser files mixed in with the toru zip, I'll have to go through it and look at the previous thread posts to figure out the correct folder paths.
i will fix this! please give me a day or two.
-angela
