4 threads found!
anim8ter | 33 | 952 | ||
anim8ter | 1 | 105 | ||
anim8ter | 0 | 65 |
(none)
anim8ter | 11 | 340 |
21 comments found!
Thread: Prismatic Glass Shader | Forum: Poser - OFFICIAL
Ah, got it! Thanks BB! Excellent explanation. Initially, I wanted the effect to be cast on a glass object against a black background. I understand now that this may not be the applicable method for that type of scenario. But it's still an awesome shader!! Thank you!! BTW, is there a particular type of lighting you think works best with this effect?
OK, I'm up to date with SR5. Unfortunately, I'm still getting the same results. Here's a screencap of my set-up. I'm using a box primitive as before. Raytracing set to 4.
Thanks BB!
Is there a way the effect can be applied to edges only just as you have in your render? Obviously I'm doing something wrong (see below) but I can't figure out what.
BTW, my raytrace is set to 2 (although I've gone as high as 4 without improvement); pixel sample set to 3. Lighting is 3 infinite and 1 diffuse IBL.
Thanks for the link and suggestion Miss Nancy.
BB, that's awesome! Yes, that's what I'm looking for. I know you described what you did, but can you also please post a screen capture of your set-up?
Thanks!
Thread: ISO Roller Derby Rink | Forum: Poser - OFFICIAL
@BB, no, I'm not after the green edge. I really do mean prismatic. Unfortunately, I don't have a reference photo at the moment but will endeavor to find one. In the meantime, what I'm after is the rainbow effect when two adjacent glass edges are at an angle and the light seemingly refracts on the edge. Perhaps a useful example would be a glass award with edges that refract when turned to the light. Very similar to cut crystal.
Hmm, I see what you mean. Thanks Laurie.
For some reason, I thought I saw a render of a diamond complete with prismatic refraction. Must've been my wild imagination.
Thread: Phonemes for Dr. Pitterbill? | Forum: Poser - OFFICIAL
Thread: "Poser 8/9 has stopped working" after IE10 Win7 64bit update? | Forum: Poser - OFFICIAL
Even though my default browser is FF, once I was able to revert back to IE 10 all my Poser issues were solved. BTW, I'm using PoserPro2012.
