2 threads found!
artdreamer | 8 | 314 | ||
artdreamer | 7 | 767 |
16 comments found!
(translated with google translate) I opened the .fbx file in Blender and exported it as .obj. Then I opened and saved all .png files again. I opened the .obj object in Poser and all the colors were right.
Thread: Poser Ate My Runtime ! | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Did it really disappear from that USB stick? Or maybe the USB stick has today a different drive letter and therefore Poser does not show it?
Thread: Modeling Programe for simple shaps compatable with Poser | Forum: New Poser Users Help
That will be a nice animation ...
There are also rocks in Poser itself and although I am not very familiar with them, I think you can use: Object 'create magnet' or Object 'create wave' to deform these stones and export them as new obj. Succes. These stones are from turbosquid.
Is it necessary to be exactly this stone? There are enough free to use stones to be found online in obj format. In turbosquid, for example.
Thread: How to remove shadow of hair | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I have no solution for the shadow problem, but I am shocked and annoyed by the image of the swastika! :(
Thread: Classic Art Contest Winners | Forum: Poser - OFFICIAL
Thread: Miki 4 missing file(s) | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
bions posted at 5:16AM Tue, 19 May 2020 - #4389465
After more research I stumbled onto an old file Miki4.exe from a previous Poser installation. I originally assumed that all content was distributed via zip files, so this was confusing. Anyway, I ran Miki4.exe and now all of the files are in place -- I can load Miki4. Just to be sure, I downloaded Miki4.zip from artdreamer as a backup. Thank you so much for your help. It is puzzling, though, that not all of the Miki4 content is provided in the Poser 11 additional content zip files.
Miki4.zip was not mine. It was put online by 'structure'! And I said thank you.
Thread: Still problems with build 11.3.740. | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I put the update over the previous version 11.2 and as far as I know I then installed everything. During the installation I placed a dot in 'Use existing preference files'. But I have lost a lot of things, a lot of .obz files anyway. But if the new version 11.3.816 doesn't really add anything, I'm not going to install it.
Thread: Missing Content. | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Radar_rad-dude posted at 7:52AM Sat, 25 April 2020 - #4387234
I installed the latest version of Poser 11.3.813 and it won't load the Paul, Pauline, Rex and Sydney characters. It looks for their .obj files and can't find them. Is anyone else having this problem? These people used to work. I have uninstalled this version and installed the previous version and now it doesn't work either. Most frustrating. The last thing I tried was downloading the latest install file again thinking it may have gotten corrupted. Went through downloading and just reinstalled it. Still the same problem. I have no idea what to do about this. Luckily, I don't use these people too often but I do like to have a complete and working program. Very frustrating development!
I also had these problems in the previous update to 11.3.740, the problems were caused by missing a lot of .obz files. Fortunately, I had made a backup for the update to an external hard drive, but it took me days to get everything working properly again. Now I get a message that there is a new version but I don't dare to install the update now. See the link
Thread: After the update to 11.3 there are problems | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
artdreamer posted at 8:55AM Fri, 03 April 2020 - #4385290
Andrus63 posted at 4:42AM Fri, 03 April 2020 - #4385241
Anyone else seeing problems with the cloth room? This looks like the same issue that arose in the first release of P11, where the simulation vanishes at the end of simulating. The work-around is to save the scene before running the cloth sim, but it wasn't a problem with Poser 11.2.
Also, artdreamer is right - the Amy hair obj has vanished. It isn't in the current legacy content hair zip (and seems somehow to have deleted the previous existing copy of the file, which is somewhat alarming!). Anyone else also not finding it?
Yes, I also have the same problem with the cloth room, thanks for the tip that I should save it first and then run it. It is difficult to think about that, but it does work.
I didn't have all my Basic Light Sets, I had to get them out of my backup.
The problems were caused by missing a lot of .obz files. I'm not quite done with restoring yet, but I hope it works out.
So ... before installation it is recommended to make a copy of your runtime files first. For Windows users you can find these: C: Users Public Documents Poser 11 Content Runtime
Thank you for the reply. My previous version was 11.2, which I installed in the fall of 2019. Luckily I made a copy of it yesterday before the update on another disk, and luckily I found the hair for Pauline. Later I try to get Paul, Rex, Roxie and Simon 2 back in the picture. It is still a long search. If I had known that this would cause such problems, I would not have done the update yet.
Thread: Why do texture map PNGs take on a blue tint ? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
