1 threads found!
Posted Jul 01, 2002 at 5:55 pm | Forum: Bryce |
bkstearns | 3 | 111 |
5 comments found!
Thread: Contest | Forum: Contest Announcements
This is a brief tutorial regarding the free effects package from Foleypro. After downloading the file, save the FoleyproFreeEffects.lst file to your Bryce folder and open Bryce. Once opened, click on the word Edit next to the word Create above the picture. You will find at the top left of the picture being edited, an upside down triangle. Click the one farthest to the left once. This will bring up a list, choose 2D Pic Textures. This should bring up a new window. In this window, click on the words Open List at the bottom. This will bring up a window that will allow you to locate the file FoleyproFreeEffects.lst choose the file from the location in which you saved it and then the open button and there you have your effects loaded. To use the effects choose an object for your picture. With object hi-lighted click on the upside triangle once again. Here you will choose the effect to apply to the object, Click the check-mark at the bottom right of the window your texture is added to the object. You may want to experiment with the Ambience and bump settings. There are literally thousands of uses for these effects. Enjoy Stay BAD...BAD 3D
The pdf files were created in Adobe Acrobat 5.0 you can download a newer version of Adobe Acrobat Reader 5.0 at http://www.adobe.com. I can also work with Foleypro to publish a word document tutorial.
Absulotely wonderful idea, and by the way I am a betetester, as well a co-founeder of BAD-3D, and have used these effects on my 300mghz Cyrix W/64mg RAM. The rendering times while using these effects have not been changed by more than seconds. I am looking forward to seeing the results of this contest. Thank you Foleypro!
Thread: Monthly Challenge! | Forum: Bryce
