6 threads found!
bof | 4 | 151 | ||
bof | 11 | 251 | ||
bof | 3 | 88 | ||
bof | 2 | 90 | ||
bof | 0 | 15 |
(none)
bof | 0 | 26 |
(none)
21 comments found!
Thanks Bar-Code i really forgot to go there.
lesbentley its exactly what i need...i dont no why i would like to use
bone for rotation only, Thank you!
Thread: PoserPro...Fall? Nope, fall is now winter. $499 and they bought Body Studio | Forum: Poser - OFFICIAL
It doesn't support Lightwave, its sure i pass....and i dont see anything that excite me to
pay $499...too bad.
Thread: Ati -- Opengl problem | Forum: Poser - OFFICIAL
Quote - Simple solution then: install the new driver, swap the cables going into your monitors, and then swap them in preferences since you said that worked properly.
HAHA!! simple but I had not thought has that (i feel a little bit stupid...)
Thank you Gareee
@Gareee
I try with older driver (7-5 to 7-10) with the same problem the only one work fine is 7-4
i can change the order of my screen without problem...
Thank !!
I found something, i have 2 screen if i disable the 2 screen everything work.
And i found another thing in my Display properties panel (settings) if i place in order
screen 1 and 2 its work but if i invers screen 2 and 1 its does not work. weird....
My setup is 2 and 1 someone know how to fix that..
Thanks!
Thread: Hide object | Forum: Poser - OFFICIAL
Ockham Thank you it work perfect. Just one thing why the line " thighLength 0 "
Again Thanks!!
BoF
Thread: Save Parent Light | Forum: Poser - OFFICIAL
Thank you!!!Â
This exatement what I have need and it's work .....
You save me a lot of work.
Thanks!!
Thread: Poser 7 Service Release 1 Now Available | Forum: Poser - OFFICIAL
@Jules53757,
I have the same problem with different obj and different setting to import.
I uninstall and reinstall with the same problem....without sr1 everythig is ok.
Someone try to import .obj file.....
I try 5 different .obj files and nothing happen...i see the name and the surface name
in material room but nothing in my view port, i try with poser 6 the same files and everything is ok ...
It's only me......
Thread: Poser to Lightwave | Forum: Poser - OFFICIAL
You can use DazStudio (free) and export your character, select LW preset and
check write surface and collect maps. All textures and obj in the same folder.
Start Modeller and load your obj and save in LW format.
Thread: PBooost Compatibility Tester for NT operating systems now in free-stuff. | Forum: Poser - OFFICIAL
Thread: Poser Object Organizer Program is now available at the Marketplace | Forum: MarketPlace Showcase
Looks good,but this program can it read the compress file .crz,.pzz... And for the zip file can i choose different name of folder for the figure and a other for the texture or is the same name like other program? BoF
Thread: Free BVH files | Forum: Poser - OFFICIAL
Thread: Posing is an art is back ... | Forum: Poser - OFFICIAL
Thread: Rigging.. | Forum: Poser - OFFICIAL
