11 threads found!
dcrich | 9 | 73 | ||
dcrich | 3 | 16 | ||
dcrich | 0 | 5 |
(none)
dcrich | 19 | 89 | ||
dcrich | 3 | 33 | ||
dcrich | 2 | 11 | ||
dcrich | 0 | 7 |
(none)
dcrich | 0 | 14 |
(none)
dcrich | 0 | 5 |
(none)
dcrich | 5 | 26 | ||
dcrich | 8 | 48 |
49 comments found!
everyone has given really good suggestions, however I didnt see this one... when doing large scenes, its a really good idea to change display for complex meshes to "box" display. This will significantly speed screen redraw. If you can change the poser figures to box display..any imports to box display..and stones...and any other object that has lotsa polygons, then you will see a quicker redraw... merging scenes is the best way to get a quick placement...you just put em all together in the end... and that suggestion about autokey...sounds very feasible! Id never thought about it, but Im gonna test it ASAP to see if that does indeed produce a quicker redraw. Flickerstreak, that was a great suggestion! BT http://www.brycetech.com/
Thread: Who would I call "master"? | Forum: Carrara
ok..Ill sneak around the gallery to the right...I didnt really look because I assumed there would be someone whom everyone would say "yep thats one"..there is with Bryce, just assumed itd be the same with carrara or rds... thanx BT
Thread: Simple question | Forum: Carrara
thanx for the reply clint the first 2 things you mentioned come with rds5.5..so Ill skip them the crashing thing..lol..rds does love to do that huh? I have a memory manager that is wonderful for Bryce..it cant do crap for rds..things still lock up if you dont shut it down (and I do have the patches) I forgot, does carrara have the four window modeller? I think it did, and that would most definately be a great improvement. how about camera memory options? you can of course save camera settings...is it easier in carrara than raydream? thanx BT
Thread: Regular Bryce contests/challenges | Forum: Bryce
Im in...assuming it doesnt kill my regulay bryce render stuff but would make an excellent "study" of techniques and would offer a pretty neat variety for effects when all are up... one of the best things I encounter as "brycetech" is seeing a vast number of techniques to perform the same effect..and this would be a great way of showing them! so lets do this! suggestions for startoff..well..start simple..work to big how about the best terrain and grayscale MUST be shown image linked thatd rock! BT BT
Thread: need help with putting poser characters into bryce | Forum: Bryce
Attached Link: http://www.brycetech.com/picts/tutpict2/Hairdemo4.jpg
lol..somebody moved my keys again... should say "got" not "go".. BTThread: need help with putting poser characters into bryce | Forum: Bryce
Attached Link: http://www.brycetech.com/tutor/bryce/brycealive.html
the actual url of the step-by-step thing with poser is: http://www.brycetech.com/tutor/bryce/brycealive.html go pictures for the steps AND if you are still confused there are flash files that will actually walk you all the way thru... luck BTThread: Does anhyone know where I can get some good grass? | Forum: Bryce
Attached Link: http://www.3dplants.com/
the ABSOLUTE BEST free site for plants! http://www.3dplants.com/ lots of grass, flowers, and more! you just gotta love that! BTThread: Printing Bryce Renderings | Forum: Bryce
Attached Link: http://www.brycetech.com/tutor/bryce/bryceinprint.html
I have a complete tutorial on printing in Bryce..including the actual calculations needed and if you're like me and just want the work done for you, there is an online calculator that does the calculation for you. :P hope that helps a bit BTThread: Compatiability | Forum: Bryce
Just answered this elsewhere I have only crashed bryce once since using ME..I used to crash it daily BT
Thread: Lightning in Bryce 4? | Forum: Bryce
Attached Link: http://www.brycetech.com/picts/gallerypicts/rain5.jpg
select the object go to the preset material and apply "green lit" once back in material lab, change the colors to white instead of green when back in scene, put a radial light at the top of the bolt of lightning... the attached scene was done this way... BTThread: Lightning in Bryce 4? | Forum: Bryce
there are 3d models of lightning bolts at Brycetech in the download sectionThread: "Off Hours" WIP Final test render | Forum: Bryce
damm that thing's 502000 byts in size! you should compress it some so more will stick around to see it! I love the bra...lol..that rocks! BTThread: Help! VELVET texture? | Forum: Bryce
if you look at your image you can quickly see the problematic areas...for instance..the shirt has no shadows. This is a function of "ambience" in the material lab...go in there and turn that silly thing off! also, if you still dont get some shadows..you can try to apply a very small amount of bump to the image. see this page: http://www.brycetech.com/tutor/bryce/brycealive2aptex2.html scroll down the the "green" part of the table in addition, there would be an option to create a more "shiny" effect to the material if you also use the bump channel as to drive the specularity of the material. luck BTThread: Somewhat new to Bryce... | Forum: Bryce
I too just nosed around your site... been a busy girl havent you? :) have fun learning Bryce...its quite addictive! BTThread: New to Bryce | Forum: Bryce
very nice job dont let us down and break the "passing image" of the mirrored spheres over water..lol hope to see more of your stuph soon! BTThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Need help out of the render zzzzzzz monster | Forum: Bryce
