1 threads found!
deuce777 | 20 | 411 |
2002 Oct 25 5:44 PM
9 comments found!
ok i got the UV mapper from there I can now veiw my prop how do i paint and save it from here it says auto update is disabled????
Thread: how can i make my own props? | Forum: Poser - OFFICIAL
hello ok i'm done my prop and save it as .obj but i'm not sure what program or how to do the text map then to edit the map template from there in a 2d program can you help i stuck ahhhhhhhh
note i also have bryce 5 to use ,will this help? it won't let me import my obj do i need plug-in?????
so once i'm done the prop in poser and safe as .obj ,then which program do i use next?to make the texture template or map and what do save it as to later bring into photoshop?i'm lost at this part but it's coming along,I'm learning it all good hahaha
wow some many helpful tips ,thanks for the new tips saving my prop and the links and programs suggested,right,this forum is helpful,hey ya'll thanks you just saved ,me hours of time...
also how do i guess make or add the texture to the turntable once i save it any tips on the next stage would be get as well ?
hey that tip with shapes will do perfect,thanks that a great help .how do i save it once it done? so I'll have it to re use ????
thanksok i will give them all a try,so you mean render the shapes into a turntable using the dails and editing tools in poser?
