7 threads found!
dmartin | 1 | 29 | ||
dmartin | 3 | 18 | ||
dmartin | 11 | 45 | ||
dmartin | 20 | 78 | ||
dmartin | 1 | 6 | ||
dmartin | 5 | 22 | ||
dmartin | 1 | 15 |
27 comments found!
Is there another uv mapper program out there?I use to have two,I have the uvmapper program you reference here,But after a few years and hard drives,I lost the other one.I think it Might have been from Steve Cox,I'm not sure.Anybody know of this other uvmapper program?Thanks.
Thread: Win 2000 Users " Poser 5 " Beware!!! | Forum: Poser - OFFICIAL
Thread: What kind of map does Airborne use?????!!!!????? | Forum: Poser - OFFICIAL
I live in central texas and according to the Airborne site, It arrived in Lubbock on the ninth,And for the last two days it said it is out for delivery.I called last nite and they said I will get it Friday.It doesn't take 6 days for it to get From Lubbock to Brownwood.I don't like Airborne,I rather Use UPS at least they leave it or If I need to sign for it, The Ups office Is pretty close.The closest Airborne hub is In Abilene.So If I have to sign for it and it is not left,It Will Be A big Hassle.I had to go through it before.
Thread: Right! Mimic 2 wishlist! | Forum: Poser - OFFICIAL
You said it,I just got it A couple days ago,and I like it so far,but having to have the cd in to launch it every time is a bunch of crap.I hope Daz takes notice and fixes that and the mil figure thing. regards, David
Thread: Bogus Serial Numbers? | Forum: Poser - OFFICIAL
Hermit,Ithink the serial number is case sensative,did you use uppercase for the letters.Maybe be it you are typing A zero instead of the letter O or vise versa.It took me A couple of tries because that what i was doing. Maybe that will help, David
Thread: Anyone else having trouble installing the Daz Beard? | Forum: Poser - OFFICIAL
Spectre3,do like adele said unzip the first installer ,then unzip the second and third installers into a place you can find them easy,then after they are both unziped,find them and double click on the new installers and it should put the files in the right spot. hope that works.It did the same thing on me,this should fix it. David
Thread: Import pz3 files--error invalid serial number of Poser. HELP PLEASE!!! | Forum: Vue
I am using Vue4 and poser W/propack on windows 2000 and I haven't had any trouble with it. david
Thread: Dina's Corset and Valkyrie.... | Forum: Poser - OFFICIAL
Yes,Dina looks great in her corset,It conform very well.You won't be dissapointed.Very nicely don. David
Thread: Help with Dina mat files | Forum: Poser - OFFICIAL
Diane,It doesn't matter what figure or texture I use,It on,it won't convert to bum.Are you trying to say Pro pack doesn't need bum files no matter what.Does it read it as bump map anyway?How then do you make A bump file? I think I may be a little confused-probably because it is 3'o clock in the morning.I think it's time to go back to bed now. Thank,s for al your help, David
Wizzard,when I load A texture into the material editor,Poser wont't convert it to an bum file.Like I mentioned above,It use to ask if you wanted to convert it t a .bum,now it wont't.
Diane,I had a case of stupid ass earlier,In the pose directory,there was your dtg dina map and the dina map for Pro Pack,I wasnt thinking to good I guess.When I use the pose mat for pro pack,it still ask for the head and body texture only once. When I load A body or head texture manually as A bump map,poser doesn't ask if I want to convert it to an .bum file.Does pro pack read it as an .bum without converting it?It does this when I load The textures manualy. I am using P4 w/Pro pack. Cin,poser is suppose to convert a bmp,Tif,I don't think it converts jpeg.In the Poser manual that's only what it says it converts.As I mentioned above,I couldn't get to convert them.I know before I had pro pack it would. Thanks, David
Ok, thanks Diane I will give it A try.I guess I should have read the read me file. Thanks Again,I appreciate your response. David
Thread: Dina into Vue problems | Forum: Poser - OFFICIAL
If you export her out poser as an obj. file-choose exact figure names and when in Vue use the material editor and choose cornea and set the transparancy upto 100 percent. You will probably have to do this with her eyebrows and lashes and public hair.At least this is one way to use her in Vue till we can figure out the missing head. Maybe this helps some. David
Attached Link: shttp://
Marque,I imported Mike and vicky both as A pz3 file and they work great.I only had Vue A few days so I am still learning it.I will try what Laurie say's and see if that works.And for what Jackson asked, yes I made sure the head was checked.As I mentioned before,when imported as an Obj. the figure turns out fine exept the eyes,and I think I may be able to fix that in Vue.I just got home from work a little while ago,so I haven't had time to play yet.I let ya'll know what I come up with.Thanks everyone for your response. DavidThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: UV Mapper | Forum: Poser - OFFICIAL
