2 threads found!
dorelia | 6 | 148 | ||
dorelia | 2 | 7 |
22 comments found!
Thread: White pixels around figure ?????? Help | Forum: Poser - OFFICIAL
I have another Idea.
My PSP is in german. I don't know how everything is named in english.
When you use drop shadow, do you mean: Effects -> 3D Effects -> Drop Shadow or named similar?
If you do use that Effect: did you activate that little checkbox at the bottom of the Window? It can be namend something like "Shadow on new layer".
when I deactivate it I get the same white Border like you do. But when it is checked the shadow does fill out the whole space behind your figure on a new layer and gets rid of that little white border.
Sorry, can't explain better :unsure:
Thread: noob-ish question on advanced (to me) lighting | Forum: Poser - OFFICIAL
...More's the pity - it would be very helpful to me when illustrating lighting tutorials if those lamp cans and flaps actually would render as part fo the scene...
Did I get it right? You would like to have the spotlight geometry visible in render for demonstrating for example the position of the light?
That would be possible. It is not a one click solution and I tried it just quickly now. So I don't know if this would affect the spotlight when you change for example the Angle end. Since I just imported the spotlight geometry (after extracting the .obj out of the .obz with winrar) and parented it to the real spot light that is casting the purple light.
I made a quick render with this imported geometry of a spot light (there is a sceond spot in the scene which just only points at the spotlight geometry so that it is visible and not black).
Thread: Poser 8 SR1 now available | Forum: Poser - OFFICIAL
And poser still does not like comas as decimal points, which is extremly annoying as european user :crying:
Thread: Poser 8 advertised! | Forum: Poser - OFFICIAL
I also noticed that P8 does not recognize a comma as decimal separator anymore and that is really annoying because I'm used to a comma as separator. Adjusting values with numeric key pad alone is now not possible anymore :crying:
Thread: P8 Library: How to remove something from Favorites inside P8? | Forum: Poser - OFFICIAL
Hmmmmmm, it does not work that way for me.
I selected my M4 (I added him to the Favorites out of an external runtime, if it does matter) and I used that button to remove him from the Favorites. It deleted my original M4 .cr2 out of my external linked poser pro runtime, really! The original .cr2 is not there anymore, but the shortcut and the thumbnail in p8's collections folder stayed. And I made sure the Favorites tab was active when I pressed the minus sign.
I have now only M4's Genitalia left in my external linked Poser Pro runtime :laugh:
Does P8 still use .xml for the ui?
I really hate the visible dials in the parameter dials. They make the parameters twice as long as needed
I love my modified xml where the dial name is not only the name, but the dial too (without the dial pics)
Thread: limitations | Forum: Poser - OFFICIAL
Don't know a way that works for all morphs at once, but you can adjust single morphs.
Click the arrow on the right next to the morph you want to change. Choose settings... and adjust the Max Limit.
Thread: PZ3 Load Problems | Forum: Poser - OFFICIAL
Do you have use external binary morph targets in your preferences under misc checked? V4 does not work with it and poser crashes when opening a pz3 that was saved with V4 and external morph targets enabled.
If it was enabled when you saved the pz3, the pz3 is permanently damaged as far as I know :sad:
Thread: Problem with Radiant Jaguar Hair | Forum: Poser - OFFICIAL
It does not look like a real hole to me. The collar of the shirt/jacket is just in front of the back hair and therefore visible through the side hair. I think you will not the see the wood behind the figure if you make the shirt/jacket invisible
Thread: Weird V4 contortions in Carrar | Forum: Carrara
I have the latest Version of Carrara, but it did happen with 6.2. too. I'm not sure if it is meant this way because I'm still learning how to use Carrara and I found and used the constraints button first with version 6.2 when I noticed, that the universal manipulator on different body parts did not work like I expected.
Thank you Sueposer. Stupid me, I did not think of changing the limits or the type of constraints :blushing:
I have the same problem. It is caused by constraints. As soon as I disable "use constraints" V4's shoulder distorts when bend.
Edit: same happens with her rThigh and lThigh
Thread: Poser Pro Released | Forum: Poser - OFFICIAL
Quote - You can import rigged Collada models in Pro Full. Since Collada don't use Posers own rigging system, Poser should have support for Collada's system too.
Where did you find the information about the rigged collada model import?
This is from SmitMicro's Poser Pro page:
**COLLADA
Poser Pro offers Data Exchange with the industry-standard COLLADA format. Gain maximum flexibility by transporting Poser content to applications such as Adobe Photoshop CS3 Extended.
Import: Geometry, Textures, Cameras, and Lights
Export: Geometry, Textures, Cameras, Lights, Morph targets, Bones, Shaders, Animation Data
Quote - By the way, they wrote something about an "up to date rigging system" in the text too - and you wouldn't call the Poser standard system up to date, if you know what you write.
On poserpro.net is a tutorial for rigging in Poser Pro.
Thread: any german speakers know what this means ? | Forum: Poser - OFFICIAL
I'm german, so a more or less bad translation :P
Hello,
I bought Poser 7 and I'm now playing with it. I would like to create something on my own, for example gloves. But I don't know how to do it. Until now I got everything I needed out of the library. Can you help me with this?
I created gloves in Photoshop and wanted to import them into Poser, but it does not work. I would be glad if you can help me.
Thank you!
Thread: What's this Hair I've Found? | Forum: Poser - OFFICIAL
