1 threads found!
Advisories: nudity, violence
douglas1 | 1 | 10 |
7 comments found!
Thread: What am I doing wrong????? | Forum: Poser - OFFICIAL
What is the problem? The only problem I can see is with your mesh. Look at your mesh and then look at your poser render, do you see what i mean? Get your mesh more uniform and you wont have these problems. Start with a spline of one side of the blade. keep your faces as regular as posible and then mirror and the add the center cylinder.
Thread: Alpha Channels in Poser for PC | Forum: Poser - OFFICIAL
The only thing that I do when I need such a memory intensive project is import to max. It handles lighting better, I don't have to trick it into using alpha maps, etc. etc. As far as I know, and I admit it ain't much (I am getting a bfa in this!) poser doesn't like to alpha channel stuff, it uses a seperate map for these things. That is wh we load a seperate bump, trans etc.
Ron is right that alpha is only and I mean only a 32 bit process. Istill haven't heard what you are using your alpha channel for!
Thread: Help out a newbie.. | Forum: Poser - OFFICIAL
also, mac has a file converter also in it's os bundle. If you have a program installed andit is available for p.c. also there is a way of converting p.c. files to mac. Email me at school kelly.douglas@uleth and I can guide you through, as I don't have mac at home.
Thread: making realistic eyes... | Forum: Poser - OFFICIAL
