1 threads found!
exzazxe | 11 | 762 |
13 comments found!
I just discovered a 'teethapart' morph for La Femme Pro .
With the tongue I first Z translate the tongue out of the mouth then apply any bend and twist before ztranslating it back into position, its easy to use the morph tool on tongue parts.
Seems I answered my own question
Thread: Poser 12 Renders | Forum: Poser 12
Liquid_Ice posted at 12:06 PM Sat, 12 November 2022 - #4449022
Thanks for responding, I suppose what I should have asked after were teeth or mouth internal morphs rather than 'fixes'. They seem to be very spaced widely apart and the scale transforms don't seem to affect the spaces, I find the tongue very hard to pose.exzazxe posted at 2:02 PM Wed, 9 November 2022 - #4448809
Anyone knows of any teeth fixes for LF and LH?
What would you like to have changed?
I realise that the most likely solution is to export and model them and edit externally but it sure would be handy if someone already did that.
BTW sorry if interrupted the previous conversation on lighting technique
Thread: Curious about converting shoe items LF to LH | Forum: Poser 12
What i do when fitting heels.
reset the LH figure size to zero
Get the heels of the foot to fit the shoe
bend and/or twist Toes (not the toes) and if necessary, the same with metatarsal (figure )
now use the opposite bend and twist on the shoes, then reset the figure
the shoe should be fitting don't worry about poke thru on sides of toes or on legs but still get it as close as possible
now click on the shoe properties and check all 5 'when conforming' options
Goto fitting room, create new fit shoe to figure setup, make sure you don't select zero figure or keep deformers
the shoe and figure should be fitting
if there is any poketru run a smooth with 0.0001 WM start at 6 iterations then try 10 then try 20 this should be enough
create a new figure and in the copy transforms unclick then click again Toes so that no toe parts are selected except for Toes
click all three options and go
when returning to the pose room hide the original shoes
select new shoes and copy morphs from figure
in properties make sure all the 'when conforming' options are selected
conform your new shoes
M4 - LH and V4 to LF
Thread: What am i doing wrong please? | Forum: Poser 12
I'm adding an additional slightly off topic question.
After experimenting with ghostship2's free lights for P12.
Is crisp filtering supposed to be better quality than quality filtering or is just a better-balanced speed v quality thing.
I ask because with those lights and various render setting changes quality filtering seems to be more.... crisp!!.
Fantastic Ghost Ship,
I also note your pay for stuff....my wishlist grows..now i just need to wish for my wishes to come true.
I have now disabled all the default lights and set 2 sss lights as the new default setting. so much sweeter.
Now that I have properly compared them, your right those old lights are surprisingly bad.
Id welcomes any tips, i don't want to wait 5 years for p13....hehe
Thread: Contemplating Poser12 upgrade | Forum: Poser 12
ssgbryan posted at 4:01 PM Thu, 13 October 2022 - #4446574
I recently discovered Ken1171 scripts as well and I think if you take a look, you will be blown away about how useful they can be.The Ken1171 scripts and Multiple GPU rendering support made it a no brainer for me.
Also, you might check out XDcrossdresser4 and XDmorpher4 from EvilInnocence.com
Thanks for your help DCArt,
At first, I thought you were crazy for suggesting that, but I listened.
I tried different lightings from different angles thinking that can't be the issue.
I tried him on the ground with an ambient occlusion and thought I am the dumb one here not DCArt.
I disabled shadows on light 1 of default settings and you were right.
THANK YOU SO MUCH FOR RELIEVING MY ALMOST OCD OBSESSION.
solved
