2 threads found!
fonpaolo | 9 | 171 | ||
fonpaolo | 3 | 53 |
234 comments found!
Hi, long time no see...
Just received a mail, telling me to upgrade my Poser 11 Pro, but I've a few questions:
First of all, after a very bad and disappointing experience with Poser Pro 11, I uninstalled it, so, now if download and install it, where I can find my SN, or do you've it already in my account?
Second, the reason why I uninstalled it: no library at all!
There may be a solution with the newer version?
Thanks.
Thread: Poser 11.1 crashes 2 computers! | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I can't help here, my problems with Poser 11 Pro are others, however I refuse to download and install the last SR, I had so many problems to persuade Windows to open my files with Poser 10, after Poser 11 was installed.
The question is: do you know or have a link to a list of the changes made in this last update?
Thread: DAZ forum broke | Forum: Carrara
For me there's no problem, but... maybe it's because I forgot the last time I logged. lol
Thread: RTE encoder not available | Forum: Freestuff
Thread: Freestuff no longer organised by software compatibility? | Forum: Freestuff
If it were only for freestuff...
My activity is slowing down more and more and with all the "new features" added here, Renderosity is helping me a lot to keep me away from here.
Thread: Windows 10 | Forum: Poser - OFFICIAL
The Windows 10 upgrade downloads the ISO. Simple instructions on how to make an install disk are here.... (they are other places as well)
http://www.zdnet.com/article/how-to-turn-your-windows-10-upgrade-into-an-iso/
Thanks shvrdavid, good to know.
As far as I know, since I've already searched in the Microsoft Community forum, for the same "problem", as was stated there all the programs for Windows 8 and 8.1 must work smoothly, for Windows 7 there may be some problems if they're old and are already running only using some "tricks".
For the hardware, if you're already running at least Windows 7, there's no problem.
Keep in mind that the free upgrade is related to the system you're upgrading and to the OS version you're using, once upgraded, the licence of the previous OS is locked with the upgrade and what version you will receive is related to the version you're using, Home, Pro, and so on.ย You can't install and use your "old" OS on another computer.
You can install it only in that system, if you change hardware ,not one or more hard disks, but processor or motherboard, there may be a request for a new validation, but you can't.
Only on the same system you can re-install the OS, also as a fresh installation, but at the moment nothing was said on how to obtain an ISO image of the OS and when it will be available, the only suggestion for now is to create an image of the system on an external drive and then use this to install everything again.
Thread: Poser libraries weirdness | Forum: Poser - OFFICIAL
I know that you're talking about Poser Pro, however I have some similar problems with Poser 10, all Adobe plugins are updated even if I don't use IE.
I opened Poser last week, last time I opened it was some months ago, everything was ok with my library.
Maybe someone has a suggestion?
Thread: Poser 9 to Blender 2.7 - How to do it successfully? | Forum: Blender
I know, I started using 3D software more than twenty years ago, always searching for better usability, performances and final results, year after year.
I was hoping an easy workflow to transfer Poser poseable figures into Blender, since I have many of them.
I already started to rig figures in Blender, exporting from Poser as object, I can't say it's easy, but it's doable, but for morphs it's really a different story.
The point is that I don't have much time to "waste" (excuse me for the term...) to have something similar at a Poser figure in Blender, I just need to fill some scenes I do for my job, nothing as a close-up, but it's better to have some versatility as I have in Poser.
At the moment I still don't like too much the way you have to pose a figure in Blender.
Thanks Lobo3433, probably I misread some posts... my bad.
So, I have to find another solution, Pro version isn't really a plausible option.
It's very strange that you can find a plugin to import almost any existing 3D format with rigging and so on, except Poser...
I'm using Poser 10, but, correct me if I'm wrong, doesn't seems to be the right application.
As you can see, the COLLADA exporter isn't really as you've posted, some options are disabled, tested with many different figures with and without weight mapping.
Thread: EZMat | Forum: Poser - OFFICIAL
Quote - Hope you figure out a way to remove materials you accidently add to a figure or prop that there are no zones for those materials in the item to start with.
Looks amazing. Thanks for the preview.
Gary
I completely agree and hope!
Thread: Renderosity Acquires Poser Software | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
