4 threads found!
gate | 10 | 1333 | ||
1 reply with content advisory
gate | 74 | 6395 | |
gate | 9 | 254 | ||
gate | 1 | 130 |
290 comments found!
You might have to try shutting down individual Windows one by one starting with the library. then open em up and dock them one by one this way you could figure out if it is just one of the features causing the problem or if it is a global issue " this is actually a primary problem to solve for the programmers " so if it would be caused just by one of the windows the issue could be fixed by letting it closed. the way I understand is that the most changes happen on the Library with integrating the Store so there might of happen a code conflict that is causing a mess on docking . also it might be a conflict by keeping the Preference files . when I tested the PP11.2 I noticed some strange behavior on install and startup affecting the Preferences. so it could be that Keeping the Preferences creates a conflict as they might not be compatible due the changes from 11.1 to 11.2 try deleting all Preferences manually to see if it might fix the issue, not just by setting it back to factory state.
Thread: Windows too small | Forum: Poser - OFFICIAL
Rather then to make windows floating this might be the fix for it to work again normally ( it is just incredible how many issues appear after the 11.2 update )
Thread: Why can't Poser do this? Or can it? | Forum: Poser - OFFICIAL
It probably depends what it is all about you sometimes just need something in addition to Poser to make things work so , just like one says to edit a CR2 take the Notepad++ it is just great to write scripts instead of doing it in Poser , but then if you say " Hey that is not the Forum for Notepad++ then there would be a problem to find out how and what could be used. and well even if it is to say " use iClone to make BHV action files that you can use in Poser then all should be just fine "
For me it is nice to read Proposals for other applications like Wolf is mentioning , it can offer new options so we can grow and not just stand still. sometimes there is the need for solutions if a Program reaches it's limits. sot the best is if People that used others can share there experiences .... Poser alone is actually nothing it is just a posing Program with some basic rigging features , so without all the other high end programs Poser and even Ds would not have any chance as there would not be any Models for them.
So for sure it is great to see and hear what people like wolf have to say even if it would be about Daz studio as we can learn from one another. Just discriminating others that use different way's sure is not very helpful to grow.
If we are honest with our selves then we could say that Ds or Poser are just Programs to start getting into 3D as they would have a long way to reach the quality of really Professional Programs .... like a kid that starts with a toy Car and one day builds the real ones
So you mentioned the 30 first seconds and I believe that Poser could manage such a sequence with not much trouble ... Your 30 sec Clip has about 13 individual sequences " Count them " this would give an average of 2.5 sec for each " Seems longer " but the brain fills the missing parts. this would give you for each sequence about 75 frames . that Clip you show has 5 of 13 full view complex acts the rest is just symbolic. So Poser with the right models would be able to handle such a clip with ease.
All this works a little like a Comic Book just that the sequence is not 1 Frame but 75 , make a comic of your short story then make a little scene of each image that you have in the comic , Put it together and voila
Also to avoid a huuge collection of saved Parts Put it once in a while together , check it , save it , delete the Parts . this trick will also help you to have the Actor's Feet on the ground without to much of a hassle .
Actually it works , rather then add new frames for a clip into your time line make a short one just as you said the first ones are working well . To prolong the sequence save your first frames ... save the last pose and cam position then start the next little sequence . so even if your sequence on one cam view is 30 sec splitt it off into smaller Portions . when gathered all parts for your 30 sec put them together but keep in mind to just keep the actual cam view . these steps will also help you to find corrections you need to make on the parts . so name each Part with the frame numbers to find it easy same with the cam and last figure pose. Work with different cameras this can shorten the work of your clip to make it longer with the same action from another perspective.... from a different angle you would think it is another sequence.
Think a little the way they were making animations on Paper then you will find a good way to make it with Poser
also Note : do not move the light to much else it will look like the sun is turning around your Actor this can be very disturbing so keep a good eye on shadow and Light
Thread: Free Texture Generating Tool. | Forum: Poser - OFFICIAL
Thread: Having issues with GoZ integration with regards to SubD | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Well sure good reasons to stay far away from subscriptions and Call home systems . I actually have not one Program running on my Machine that does such. SM gave the option to remove the call home with a Permanent Licence so that one is the last one for me unless Bondware removes hes 7 day Call home system and makes it Permanent.
The way they forced People to Install the new Poser 11.2 can be compared like holding a Gun on your head saying Sign the new contract with us or we pull the trigger. So most just silently Signed there new conditions and accepted them with a gun on there heads.
Thread: Fun Thread | Forum: Poser - OFFICIAL
If you prefer the simple styles here are some oldies that were Released as Free hero collections build using the Native Poser 4/5 Models this is just a small part of what had been released and guess still around .... Some are very neat for the Period they were made but well not really standard for our time unless you would make comic style renders !
Thread: Fitting clothing to La Femme character | Forum: Poser - OFFICIAL
hborre posted at 9:28PM Wed, 04 December 2019 - #4372282
There is no module for La Femme in Wardrobe Wizard so it would be pointless to attempt it. Besides, support for it has been dropped by Bondware and no longer exists in Poser 11.
Well the tutorial if you read it is not the section of the WW to fit from one to another Figure it is the section to Merge Morphs of a Figure this makes it omni compatible for any Figure used , there are many features in the WW besides fitting from one Model to another. The feature used is Dials to single Morph , there are also other ways to do it if you do not have the WW , you simply would have to export the Morphed Figure as OBJ then load the OBJ as Custom morph into the figure , actually the alternative for the WW in this case, or lets say the common one that was Primary used to create a single custom morph out of many. third alternative would again be doing it using the ... Ohh well this would end up as Book LOL ... But just in case that the OP still has the WW as you could keep it if you still have PP11.1 or someone just sends a copy of it
Would it be to fit from one to another model there are better ways then to use WW , CrossDresser or CC it also would be another tutorial :)
If you still have the Wardrobe Wizard this tutorial might be of good help but is actually used as shortcut it can also be done without it. I have not tested it with La Femme but it should actually work for most situations. " Might have to update the Tutorial to the newer versions one day "
