11 threads found!
gerberc | 2 | 421 | ||
gerberc | 5 | 137 | ||
gerberc | 8 | 1331 | ||
gerberc | 6 | 83 | ||
gerberc | 14 | 138 | ||
gerberc | 11 | 344 | ||
gerberc | 5 | 146 | ||
gerberc | 3 | 181 | ||
gerberc | 7 | 277 | ||
gerberc | 2 | 115 | ||
gerberc | 5 | 127 |
38 comments found!
Found a simple solution not involving updating to MacOS Monterey: Just set the USE_OPENGL to 0 (was 1) and everything is fine.Â
Thread: How to convert library thumbnails from .rsr to .png? | Forum: Poser - OFFICIAL
@EldritchCellar: Seems RSRconv for mac is no longer available. Do you have a copy and would you mind to share it?
Thread: Memory issue with Poser 6 and Windows XP home | Forum: Poser - OFFICIAL
Bingo! Thank you both very much and a special thank you to svdl for the clear description how to resolve the issue.
My page file was 2047 MB, obviously too small. Checked with Vue d'Esprit too and found that Vue uses 100% of the processor capacity while rendering. Poser 6 obviously doesn't support hyperthreading.
If you ever are in Basel, Swiitzerland send me an email, I owe you a beer or two ...
Regards,
Christoph
Thread: More newbie questions ... | Forum: 3D Modeling
Thank you both. If NURBS in fact are splines I think I'll try MoI. This program seems to have a clean user interface and is consideably cheaper than Rhino.
Regards, Christoph
Thread: A free tree generator ! | Forum: Vue
Thread: Dripping/Hanging Moss | Forum: Vue
Thread: Making drops of water on skin in Vue 6 Esprit? | Forum: Vue
My memory didn't work correctly as usual. For those interested here is the correct name of the Photoshop brush set I had in mind:
Product:Â Water Droplet Kit for Photoshop
Creator Name:Â Arie L. Stavchansky (LazloHollyfeld on Renderosity)
Email: Â Â lazlohollyfeld@sbcglobal.net
Copyright:Â 2004 by Arie L. Stavchansky
Unfortunately I can't tell you if it's still available.
Christoph
I have once seen a package for Photoshop in the Renderosity store called "drop maker" or something similar. With this you could paint drops of water over any texture.
Regards, Christop
Thread: Can Vue actually make non-grainy renders? | Forum: Vue
I think you can bring down the grainyness to an acceptable level with appropriate render settings. The "superior" setting is not good enough and the "ultra" setting is too slow. Here is what I use:
These settings do the job for my taste in most cases, see my gallery for examples if you like.Â
Of course the price is rendering time. So thanks for the "Neat Image" hint, I'll give it a try.
Best regards,Â
Christoph
Thread: Adding clouds in Atmosphere editor crashing application | Forum: Vue
I had the same problem with Vue 5 Esprit. If you have Vue 5.10 you will have to go back to version 5.09. E-on says they have fixed this with version 5.11, however I have not tried this upgrade because it is still beta. 5.09 works fin for me.
Best regards, Christoph
Thread: ebot down? | Forum: Community Center
It was just a delay, got all messages this morning! Sorry for disturbing but I never observed any delay up to now! Thanks for your help and best regards, Christoph
Thread: Triangle artefacts | Forum: Vue
I don't have a modelling application, so I can't try untriangulating and polygons. Vue can invert surface normals of meshes however. I tried this and then all parts of the mesh became invisible (not black), there was nothing left. I think this is an indication, that all surface normals point in the right direction, i.e. to the outside of the mesh. I'm not absolutely sure about this however.
You are right, it's a Hankster rock formation. I had similar artifacts with other meshes too, but this one is the worst by far up to now. I like the models a lot just the same ...
Thread: Poser 11 Pro Mac crashes when loading pre-assembled scenes | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
