12 threads found!
goofball | 3 | 129 | ||
goofball | 2 | 127 | ||
goofball | 0 | 55 |
(none)
goofball | 2 | 207 | ||
goofball | 1 | 81 | ||
goofball | 9 | 235 | ||
goofball | 3 | 255 | ||
goofball | 35 | 1064 | ||
goofball | 2 | 162 | ||
goofball | 3 | 62 | ||
goofball | 6 | 155 | ||
goofball | 4 | 118 |
26 comments found!
Thread: Eovia Announces Carrara 5 | Forum: Carrara
Thread: Deeper, Baker... | Forum: Carrara
Baker is helpfull with Anything Grooves objects, create the object and apply an Anything Grooves deformer with the bump that you would like, then try baking it into a normal map.
Thread: How to make a realistic snow shader?? | Forum: Carrara
If you mixed Shoestring shaders iridescent with spot and fake fresnel you could have mutli-spectral colored sparkles.
Thread: Test renders from a future plugin | Forum: Carrara
Thread: Re: Sponza Atrium Lighting | Forum: Carrara
It was an HDRI map of a city, containing everything from the sky to the road. I cranked up the intensity I don't remember to what but it was high.
http://www.renderosity.com/viewed.ez?galleryid=557833&Start=1&Artist=goofball&ByArtist=Yes I did this scene in Carrara with only HDRI lighting. I think it competes with some of the other renders.
Thread: Posilbilities | Forum: Carrara
I've had some success in creating procedural water within carrara, I'm a little busy right now, but when I get a minute I'll post a screen of a decent texture.
Thread: Need printable User Manual | Forum: Carrara
I've got an official manual for Ray Dream 5.0 I'd be willing to give you. If you are interested in that contact me and we'll arrange for shipping.
Thread: Just got C3...Lighting question... | Forum: Carrara
On the right-hand side of your screen, there are a few circle icons, the top one has an arrow pointing up, if you click on that it will take you to those properties. I can't post a screen now but I will a little later.
Try going into your display properties and setting the lighting mode to actual. It will give you a rough representation of what is happening.
Thread: tutorials for creating sun bursts and prominences etc. | Forum: Carrara
alkart2003, I wish I knew of some tutorials like that for Carrara. I've needed similar things like that for presentations and videos that I do. In the end, I've just had to do trial and error to achieve the look I require in the time alloted. Now I don't claim to be the athuority on Carrara, but if you need some help and have some photographic refrences to send me I'll see what I can do. I wish I had more info to give. Good luck with the project. Chris
Thread: Landscape WIP | Forum: Carrara
I like the atmosphere and the depth of field. The shading needs a little work, but other than that I think it looks great.
Thread: Need Help with Rendered Alpha channel | Forum: Carrara
