12 threads found!
icprncss2 | 4 | 133 | ||
icprncss2 | 3 | 86 | ||
icprncss2 | 2 | 93 | ||
icprncss2 | 10 | 195 | ||
icprncss2 | 1 | 68 | ||
icprncss2 | 6 | 159 | ||
icprncss2 | 2 | 104 | ||
icprncss2 | 1 | 40 | ||
icprncss2 | 2 | 53 | ||
icprncss2 | 1 | 97 | ||
icprncss2 | 1 | 305 |
1,111 comments found!
The hair in the pic looks like a wig or has been lacquered within an in inch of it's life. At first glance, it looks fairly real but if you take a good look at the color, texture and the way the hair falls, it looses the realism.
Thread: Importing obj files into Poser | Forum: Poser - OFFICIAL
Thread: Conforming problem | Forum: Poser - OFFICIAL
Thread: A Dev Foundation for M4? | Forum: Poser - OFFICIAL
When you create the developer figure, make sure you turn off IK. Even if you zero the figure, open up the joint parameters and check to make sure the hips, knees and feet are zeroed in the joint parameters window. It takes a bit more time but checking all the joints before saving to the library can save on hair pulling later on.
Thread: surgical/nurse/doctor scrubs for M4 | Forum: Poser - OFFICIAL
Oskarsson has prison clothes for Genesis over at DAZ. He has a prison jumpsuit for M4 here in the MP. You might have to kit bash and use a transmap to turn the the jumpsuit into just the top. It lacks the pocket as well. I've refit the V4 scrubs a couple of times. They take some work with morph brush to fix the breast area.
Thread: Making a prop with Poser Primitives | Forum: Poser - OFFICIAL
You can use the grouping tool to spawn a prop. You can also use it to create mat zones. Or, you can export the prop as an obj and save it. Roadkill is another free UV mapper. Be sure to download the Maya plugin version as that also includes the stand alone version.
Thread: I suddenly needed Hiro 4 and I can't use him for some reason. | Forum: Poser - OFFICIAL
Did you initialize both the M4 morphs ++ install and then the H4 morphs ++ install? Each time you install a new morph set (A4, H4, the Elite morphs, ect...) you have to re-initialize them. Even if you did, I found that you have to re run the bat or cmd files periodically. Especially if they stop working. If that doesn't work, try deleting both M4 and H4 and doing a clean install.
Thread: More powerful OBJ importer for Poser? | Forum: Poser - OFFICIAL
Thread: OT- King Philip | Forum: Poser - OFFICIAL
Thread: Another questionalble follow | Forum: MarketPlace Customers
I don't click on any links. I go to my account profile, click on the followers and then change it to "unfollow". For my own security, I am not following anyone nor will I allow any to follow me.
Thread: Has Renderosity Been Hacked? Check your credit cards | Forum: MarketPlace Customers
Much as I sympathize with Rendo, the security failed. I am careful regarding CC's. Even if Windows stores the card info on the home system, I always make sure that either numbers are left out or transposed so I have to add or correct them when making the actual purchase. I don't use paypal and I have no social media accounts. It didn't come from DAZ because we use a card there that we do not use here and it is fine. It isn't Amazon because I they were the first merchant I went after. Granted, they didn't get much because LifeLock caught the weird charges on the business card and alerted me but don't put your fail in the cloud. It is in no way secure.
The business CC and my personal debit card were hit within a week of each other. Bank of America keeps placing holds on any purchases from Rendo (even with the new cards). Fortunately, my debit was hit before the direct deposit hit so they didn't get anything. This is a real pain as I have to take time out to go over to the branch with hard copies to compare to their transaction list. It is slowing down projects to a crawl.
Thread: Purchased items not showing | Forum: MarketPlace Customers
I'm having the same problem. I noticed it in the VGS category. It's making it hard to shop.
Thread: We need this hair shader for Poser! | Forum: Poser - OFFICIAL
