3 threads found!
jerbear64429 | 28 | 688 | ||
jerbear64429 | 5 | 233 | ||
jerbear64429 | 1 | 121 |
14 comments found!
Far as I know, the last version that works for importing Genesis 2, 3, and 8, is DSON Importer 1.1.3.50. I do have DSON Importer 1.2.0.12 just in case.
Thread: DSON Importer not creating PMD files - Please Help | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
There was no change. object file created from .DUF. .CR2 created. Still no .PMD file created. Same results. Textures load perfectly as well. Still seems to be a problem with DSON Importer 1.1.3.50. I have tried to chase down any incompatibilities.
I have the AVFix, but just in case, I still have my old Shaderworks Library Manager 2.6, so I'll give it a try. I'll let you know if there's a change. Thank you for your help.
I have Daz Poser Importer Installed. I use Dimension 3d XL library manager to set up the import, no need to export from DS. Library manager creates companion files.
Everything works but the .PMD creation. The geometry object file and .CR2 are created. The textures are linked.
@hborre,
That's correct. I haven't started importing G3 or G8 yet. If the importer won't create a .PMD, but shows it in the .CR2, I'm afraid to even try Genesis. None of the joints are working properly. There doesn't seem to be any JCM. Instead of the joint's bending, there is improper movement with "Stretching". Every joint becomes dislocated.
Until there's a solution, I have the old Tyrannosaurus DR, so I will just go what I've done for the old Daz African Elephant and others. I went to the materials room, and generally all that's there is a diffuse and possibly specular, and sometimes a bump. I will generate new maps, add in ambient and ambient occlusion, and normal maps. Then adjust everything to render nicely in P11 Pro. The African Elephant actually came out quite nice. I can do all that for TRexDR and the rest of my dinosaurs DR. I have been doing this with a lot of my many years of Poser content with generally nice results when the models were nice.
My renewed interest in dinosaurs was sparked when I found a particularly nice Jurassic Park style high electric fence system in .OBJ format at ShareCG. Once imported and Poserized, it looked so nice, it begged for dinosaurs to run amok! I just thought it might be easier to import the very nice looking Tyrant King, than retex the DR hoping for tolerable results.
Figure was zeroed. All parameter dials were zero. I'm really not sure what to make of it.
Manually. When I import it, zero it, and drop it to floor, it looks great. I just can't pose it at all. it stretches, then becomes dissociated. Thank you for your help!
This isn't with Genesis, this is with all DS characters and props. Does the Importer only work with Genesis X, or with all newer DS content? My Genesis stuff other than Genesis 3 and 8 have poser Companion files. I also have Dimension3d XL manager. What I am working on now is the DAZ Tyrannosaurus Rex. I have tried others in .DUF and nothing comes out right.
@hborre and @bdpoppa,
Thank you for your replies.
I have the .PMD unchecked in P11.
I also hit cancel, the character loads fully textured, but posing is impossible because the joint zones aren't correct or something. The joints don't actually bend, parts move, but they just stretch out of bounds.
Thread: Can't activate Poser 11 on new laptop | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
