8 threads found!
joshS | 5 | 187 | ||
joshS | 2 | 106 | ||
joshS | 2 | 77 | ||
joshS | 2 | 160 | ||
joshS | 3 | 115 | ||
joshS | 7 | 135 | ||
joshS | 5 | 130 | ||
joshS | 1 | 71 |
17 comments found!
Thread: After effects training | Forum: Photoshop
Thread: Jumping Layers, QUITE frustrating. | Forum: Photoshop
Thread: Sepia Tone? How do you do that in PS? | Forum: Photography
if your using version 7, in the actions palette there is a default action called sepia toning. click on it and then click 'play selection'. hope that helps
Thread: BCE | Forum: Photoshop
Thread: walk designer question | Forum: Poser - OFFICIAL
Thread: DECEMBER CHALLENGE entry! | Forum: Photoshop
Thread: Hello & questions about lenses & such :) | Forum: Photography
Hi
A good trick for getting macro shot without a macro lens is to unscrew the lens and turn it round (so it's in reverse). To focus, move closer or further away from the subject. If your camera has a screw on mount you can get a reversal ring to attach the lens to the camera (never actually seen one so I don't know how much they cost), if the camera is bayonet mount you'll just have to hold the lens in one hand and the camera in the other.
Itd be easier with a macro lens but til you get one this will at least let you get some macro shots.
Thread: question for anyone familiar with ImageReady | Forum: Photoshop
Thread: ImageReady question | Forum: Photoshop
Thanks for the suggestions, but i found a way around it, put a copy of the last frame at the start w/ no delay, i assume there is a better way to do it but it works ok for what i want. thanks agian josh
Thread: Messing with other people's pictures | Forum: Photoshop
This was done in the Poser gallery last year "Post render game" with some pretty cool results.
Thread: Does Anyone know How to Move a Document Window? | Forum: Photoshop
to change the colour on the bar, go into DISPLAY PROPERTIES (right click on the desktop and select properties. then click on APPEARANCE then under ITEM, select ACTIVE TITLE BAR on the right u can select what colour u want to use. Hope that helps (would of included a pic but i couldn't get it to work) josh
Thread: Mouse Pointer | Forum: Photoshop
