We couldn't find any threads matching the specified search criteria.
4 comments found!
Volumetric lights are editable as you have discovered. :]
However, it isn't enough to increase the intensity of a light. You also have to play with the colour, softness, falloff, lensflares, shadows/dust etc etc. The higher the value in the shadows/dust selection, the more intense the effect. (Be warned the rendering will increase drammatically). This also applies to other aspects of volumetric lighting. The higher the value the more intense the effect. Except perhaps with fall out values.
The intensity effects such as power, dust/shadow/lensflare affect the amount of visible light that 'light' will show in your scene; spread and fall off effects the length and width of the light.
Never be afraid to edit each and every setting available when choosing the right light for your scene, if you dont like it undo it, if that doesn't work, delete it and try again with a new light.
(I would suggest you save your scene first before applying radical changes, just in case you decide you have gone a little bit overboard or crossed over to the extreme side of editing)
A Personal opinion if I may: 400% is ok if that subtleness is what you are aiming for, usually 600% + is even better; sometimes even overlapping the light with another one, slightly different in colour, intensity, light gel, etc is better (depending on the effect you are trying to achieve) Layering elements can usually be more effective than relying on only one element to achieve one's goal.
Have you considered quadratic lighting? You have two types available to you in vue 4 ~ quadratic spotlight and quadratic pointlight (both volumetric). These may get you closer to achieving your desired effect.
Just a few idle thoughts that might assist. :]
Thread: CURIOUS LABS RELEASES BETA SERVICE RELEASE 2 FOR POSER 5 | Forum: Poser - OFFICIAL
Thread: WISHLIST AGAIN | Forum: Vue
Vue's Primitives are not UV mapped. This has been a bug ever since I can remember. This would be really nice to have.
Thread: To the Moderators | Forum: Community Center
If you cant say anything nice don't say anything at all SHONNER. If you don't like her artwork, keep your opinions to yourself. If you don't consider her artwork artwork, shove that opinion in a pipe and smoke it till the cows come home. Here tosses SHONNER a dime Call someone who cares what you think!
Thread: Volumetrics lack volumn? | Forum: Vue
