7 threads found!
kyo | 0 | 21 |
(none)
kyo | 5 | 200 | ||
kyo | 4 | 73 | ||
kyo | 2 | 71 | ||
kyo | 3 | 72 | ||
kyo | 2 | 16 | ||
kyo | 3 | 22 |
7 comments found!
Thread: need little props to electrostimulate my figure | Forum: Poser - OFFICIAL
well, your patch props is a good thing to start a realistic job, i had just used some python script pre_made before, I'm interesting to try your script altought .. i have seen others way to fit meshes for clothes especially when the clothes not conform to the figure, may be a other way to do (i believe it transfer meshes surface of body to clothing prop, but i'm not sure...) PS : i had recently uninstall all kind of messenger soft because of some bad viruses,but i can reinstall one if you need to talk directly, just tell me wich one... an your ID i work in swiss.
Thread: multiple render with a script ? | Forum: Poser Python Scripting
well, thanks for answering... smiller1 : the 2d graphic (aka photoshop) not good for what i want: A6 - 300 dpi A5 - 300 dpi A4 - 300 dpi A3 - 300 dpi if i render the bigger size in 300 dpi [ex: A3 in 300 dpi can give me a A5 in 600 dpi (without quality loss) but i need too a A4 300dpi to give me A6 600 dpi ....] in fact i 'm looking for a script wich could be easely customised to save time, because sometime, print machine Pro ask for 1200 dpi, other time 300 dpi depending weight of paper type... I hope Poser Programmers fix this in poser 6, a kind of batch rendering with size,resolution and save location options, for the night working computer. i 'm boring of theses renders you never know when end comes, just pray for computer never crash before end of render :-)) especially on windows OS...
Thread: WALK DESIGNER : incorrect loop with sequence file render | Forum: Poser - OFFICIAL
thanks for answering, well, i'm confusing too... :-)) the transition seems too hard, i explain : when you are watching animation ,you detect a missing part from one part of the walking cycle,... well, in fact , when i used the WD the default number of frame was 120, then i reduce to 80, (thinking that poser adapt the cycle to the frame number, spacing the movement of lower body, i did it to decrease weight pictures to import in flash... may be a mistake...) then , i try another time this evening, (at this time i work on other project in my office...), i'f you're back in forum tomorrow, i 'll tell if all fine... many thanks... and big apologize for my english writing (shame on me)
Thread: looking for a easy way to adjust AV skeletton inside Mike 2.0 | Forum: Poser - OFFICIAL
well, just a travellin cam around body to see through the skin , no motion body... so i have to adjust joint parameters , But is there some script to automatize this ???
Thread: How to make thumbnail.rsr with little circle behind figure as original P4 files | Forum: Poser Technical
