20 threads found!
lingrif | 1 | 16 | ||
lingrif | 9 | 74 | ||
lingrif | 6 | 66 | ||
lingrif | 3 | 25 | ||
lingrif | 3 | 160 | ||
lingrif | 5 | 3352 | ||
lingrif | 1 | 61 | ||
lingrif | 9 | 220 | ||
lingrif | 2 | 237 | ||
lingrif | 7 | 283 | ||
lingrif | 7 | 207 | ||
lingrif | 12 | 349 | ||
lingrif | 5 | 119 | ||
lingrif | 12 | 203 | ||
lingrif | 10 | 207 |
563 comments found!
I always uncheck Limit OpenGL Polygons and Maintain Instant Draw frame rate. Helps in big scenes and resources start to drop. Also helps if your display has a tendency to turn objects into boxes.
Thread: Octet-Stream??? What the heck is this? | Forum: Vue
PaganArtist,
Be sure you are running Vue 6.5 or higher - it's a posted requirement at the Store.
Lin
Thread: Upgrade advise needed... | Forum: Vue
When I installed Infinite on my Vista 64 Ultimate laptop, I created a directory called C:Vue and installed the program there with no problems. My content is in C:Vue-Content. Having no problem with that either.
Lin
Thread: Name your renders ! | Forum: Vue
How neat. That opens up a realm of possibilities I hadn't thought of. I could use housing development.community names in my area. Never thought of that. The possibilities are endless, lol.
Thread: Happy Holidays.... | Forum: Vue
Thread: Christmas Lighting Challenge | Forum: Vue
This looks like fun. Peggy, I downloaded the obj format and it came with an .mtl file so everything is textured, or at least different colors.
Lin
Thread: Nikolaus day in Germany = some vegs for you | Forum: Vue
Thread: Splashes - what do you think | Forum: Vue
I really like what you're doing, Wabe. I think the format you are working with will be extremely usable. Looking forward to the finished product.
Thread: Exporting plants | Forum: Vue
This was fixed in a recent release. be sure to apply the latest update and it should work fine.
Thread: Odd texture problem with some .veg files | Forum: Vue
For Vue trees, I usually have the best luck with World Standard, for some reason. It works fairly well with this tree
Thread: Ecosystem..getting objects above ground? | Forum: Vue
You might also try the Absolute offset from surface setting in the material editor. You will probably have to play around a bit to get the effect you want but you can get objects hovering above ground this way
Thread: Improving Vue display | Forum: Vue
Try moving your Instant draw and Background draw sliders way over to the left.
Also, uncheck Maintain instant draw frame rate and Limit OpenGL polygons.
That will help your display.
Thread: Tiling terrains..... | Forum: Vue
A fellow I shared an office with for years was a Gamer - he lived for it. When I got interested in Vue, he would bring in books and magazines about the games so that I could see the artwork and I was fascinated and amazed. The talent displayed in creating those imaginary worlds was awesome. If I was younger, that is a field I would have loved to go in to.
Thread: XP Pro 64 bit and Vue | Forum: Vue
Sittingblue
In the task manager, right click on the running Vue Infinite and you can change priority there.
Thread: Nedd Confirmation | Forum: Vue
Actually, it happened before 6.5. Can't remember when but it's been a while.
Thread: What are some good option settings? | Forum: Vue
