2 threads found!
Posted Nov 05, 2012 at 2:09 pm | Forum: Carrara |
lsrgroup | 5 | 214 | |
Posted Dec 19, 2011 at 2:03 pm | Forum: Carrara |
lsrgroup | 4 | 118 |
4 comments found!
Thread: A bit of an off-topic, but not completely: Best Screen Capture for tutorials. | Forum: Carrara
Check out ScreenHunter. As I remember it, it's free or at least you can test it for free. I think it might do everything you need.
Thread: Using Poser files in Carrara | Forum: Carrara
Thanks,guys. I bought the program and have been playing with it for several hours with no success. It comes as three zip files, one of which is a tutorial about using it within Poser - not my interest.
The unzipped files don't install into the Poser and DAZ locations like the DAZ downloads do so I placed various files where I thought they would work. They didn't. I tried several locations without success.
I finally managed to bring a couple of their scenes into a Carrara file. They only have one set of buildings within the 81 blocks. I should have looked at that more carefully before I bought it because I was hoping to create some scenes with a variety of buildings.
Anyway, there are some nice textures I should be able to use and I've learned a good lesson about buying Poser fiiles for use in Carrara. Thanks for your interest. I appreciate it.
Thread: .obj files | Forum: Carrara
Chris:
Thanks much for the instruction on exporting from Carrara and importing into Poser. I tried it and it ALMOST works. By the way, I'm using Poser 8 and Carrara 8 Pro.
I can now import each component into Poser and manipulate them. For whatever reason, they import in different sizes than what they were in Carrara. Also, as I understrand it, you said they will load into place. They don't, even though I did not check the "load on floor" or the "centered" boxes in Poser.
I'm guessing that I don't have the correct things checked in the Carrara export and the Poser import dialogue boxes. And you said not to move them in the 3d tool and I can't figure what you are referring to.
Could you please give me some guidance to correct the problem. Thank you. I really appreciate the help.
Mal
Thread: The Plant Factory | Forum: Carrara
