53 threads found!
luciferino | 2 | 26 | ||
luciferino | 0 | 28 |
(none)
luciferino | 0 | 56 |
(none)
luciferino | 0 | 35 |
(none)
luciferino | 6 | 124 | ||
luciferino | 0 | 77 |
(none)
luciferino | 2 | 104 | ||
Advisories: nudity
luciferino | 14 | 229 | |
luciferino | 2 | 150 | ||
luciferino | 4 | 143 | ||
luciferino | 5 | 126 | ||
luciferino | 9 | 225 | ||
luciferino | 5 | 187 | ||
luciferino | 6 | 242 | ||
luciferino | 5 | 104 |
252 comments found!
Thread: Poser 7 SR3 is case sensitive to texture filename extensions | Forum: Poser - OFFICIAL
I forgot to tell that the files is separate in two part, have you download both??? ciaoo Orietta
bye bye ans kisses ^_^
Ciao i not try to understand in mine pack not existe two texture file with this name but there is a
VIRGGEN.jpg a
VIRGGENB,jpg
and a VirggenT.jpg that are for the mat of the genitals of virgilius
are you sure to not apply the wrong texture ???? this is the forst time that i listen some of this, let me know and if i can help you tell me
ciaoo Orietta
Thread: Makeup kits for V4 - How to use? | Forum: Poser - OFFICIAL
Hi moon like i've before write you the make up are done for v4 and fit for a 3000*3000Â face of v4, but not all the v4 face texture are equal or all we have the same v4 , so you only need use your program photoshop or paintshopro or corel for fit it with some adj for your texture face, you can use rotate, wrap, resize, but if you need more help i will be more happy of adj it for you, ciaoo Orietta
Thread: psd layout problems with V4 products | Forum: MarketPlace Customers
Hi first of all i want clarify two thing
Â
 2) the eyes i use it in mine own product and i not find any of the problem you tell but if you want why simply not rotate it.
Is an add on for merchant resource not a complete texture set that like i can see by mine report if you have bough mine me other time the eyes are all done in the same way and you are the only that have found problem, I can help you if you not know like rotate it this si what i can but i think that before to put some in the forum you need ask at the merchant.
I'm always ready to help ask at you want i can do a lot of thing if you ask  but if you not ask i'm not a mage.
I hope this can help regards Orietta
Thread: Perfect Touch Kit for V4 | Forum: MarketPlace Showcase
Thread: Aberon sidhe | Forum: MarketPlace Showcase
Thread: LM LUXIFER for M3., DAVID, HIRO | Forum: MarketPlace Showcase
Thread: exceded maximum download | Forum: MarketPlace Customers
