3 threads found!
manihoni | 3 | 565 | ||
manihoni | 0 | 77 |
(none)
manihoni | 0 | 310 |
(none)
9 comments found!
Thread: Watermark for your SuperFly Renders | Forum: Poser - OFFICIAL
Hi, everyone.
I made a new FireFly WATERMARK with my arrangement of SUPERFLY WATERMARK.
You can download a set of 4 PNG images with opacity of 25, 50, 75 and 100% from the following URL.
Thank you
http://www.manihoni.net/dl.php?dl=Watermark_FireFly_025-100.zip
Thread: My Poser 7 won't open | Forum: Poser - OFFICIAL
Please read HTML manual first, force_sensitive.
"How to send a report about troubles of SkinBlender" is written in HTML manual.
OK?
hi, force_sensitive.
Do you have problems of SkinBlender with Poser 6 ?
SkinBlender is supporting only "Victoria 4.2" base and "Michael 4" base.
This "Product Requirements" is written in a product page and Readme and HTML manual of SkinBlender .
And "How to send a report about troubles of SkinBlender" is written in HTML manual.
If you have problems of SkinBlender, Please read HTML manual first.
Or... If you have problems of other product, Please move other or new thread.
This thread was built by a user of SkinBlender, and discussing about SkinBlender.
Thank you.
Thank you for your response, TG :)
I also guess that this trouble probably occurred accidentally by other reasons when SkinBlender is installed.
I don't know how picky Poser is, but since I think this is made on a Japanese system,
there COULD be a stray character ro klanguage coding or whatever somewhere.I've heard that there are products that won't work on Japanese or German Poser installs.
Since I'm using an English Poser I don't know for sure, but that might be the cause.
Yes, My development environment is "English version Poser" and "Japanese version WinXP".
I also experienced that errors occurs by some programs in Japanese version Poser or Japanese version OS.
These most causes are insufficiencies of avoiding processs of "errors of language encode/decode" in these programs.
Of course, I add avoiding processs of "errors of language encode/decode" to SkinBlender.
These process are performed on Python interpreter level without OS.
Therefore, I cannot guess "a possibility that the trouble of OS level will be caused by SkinBlender."
Addition:
One of the causes which a TEMP file damages is a trouble of HDD.
Even if you do restoration and re-installation of a Win system, unless the trouble of HDD is solved, a new trouble may occur.
First, please check the condition of HDD.
Regards, ManiHoni
Hi, all.
I am a developer of "MH skinBlender".
It's possible that the Skinblender changed something in your registry.
If the product includes the PIL (Python Image Library) setup, it may have
used the registry to change the Python Path, and somehow altered
other things connected with Poser's ability to install.
SkinBlender is a very simple and general Python script for Poser.
Therefore, change of registry does NOT occur by this.
And, change of the configuration file (Poser.ini) of Poser does NOT occur by this, either.
I guess whether the TEMP file of Poser is damaged.
Please try deletion of a TEMP file of Poser manually, and start Poser.
When a TEMP file does not exist, Poser generates a new TEMP file automatically.
Regards, ManiHoni
Thread: Question for Japanese Members: MH SkinBlender .. ?? | Forum: Poser - OFFICIAL
I appreciate that you get interested in "MH SkinBlender" :)
Now, I am going to brush up this tool.
Perhaps, this tool will be released at the end of this month at RMP.
Regards
ManiHoni
