107 threads found!
markdc | 4 | 225 | ||
markdc | 0 | 87 |
(none)
markdc | 2 | 51 | ||
markdc | 3 | 41 | ||
markdc | 0 | 245 |
(none)
markdc | 6 | 358 | ||
markdc | 11 | 286 | ||
Advisories: nudity
markdc | 5 | 327 | |
markdc | 1 | 65 | ||
markdc | 8 | 215 | ||
markdc | 3 | 171 | ||
markdc | 7 | 353 | ||
markdc | 6 | 164 | ||
markdc | 6 | 198 | ||
markdc | 2 | 135 |
550 comments found!
Thread: Auto Group Editor | Forum: MarketPlace Customers
Quote - I keep getting an error saying that IÂ need a new key! I bought it roughly a month ago. It Worked fine for first couple of times, then nothing. The only key I used is the one that came with the zip file, I don't recall getting any other key code, unless my spam filter ate it. I have sent marcdc an IM, and I'm awaiting a reply, is there any other way I can get my personal key code? :(
I sent you an IM.
-Thanks
Mark
Thread: QuickConform License Key | Forum: MarketPlace Customers
I sent a IM. The best way to contact me is at http://www.3dutils.com/support.php
I can't browse Renderosity during most of the day (it's blocked).
-Mark
Thread: AutoGroup Editor question... | Forum: MarketPlace Customers
Thread: Need help please | Forum: MarketPlace Customers
Quote - Hi i bought visualmaker but i can't use it becouse the key has expired
please check your site mail
Thread: Problem with Autogroup editor | Forum: MarketPlace Customers
Quote - I recently purchased Autogroup editor and I'm having some problems.
I tried PMing the vendor, but haven't received a response yet.
I am trying to use the product with some clothes I had made and Jessie.
For some reason, Jessie does not have a .cr2 or a .obj, instead it is a .crz and .obz
I tried using these, but Autogroup editor won't even recognize the files, so I changed the extension.
When I load my object, then load my figure, I get the please wait window and then it sits there. I have tried on two different PC's Home and work. The work pc, I left over the weekend and it never changed, the home pc I did while I went to work and it never changed either.
am I doing something wrong? Does it not support this character?
Just uncompress those files using poser. There is an option in Poser to save as compressed. You just need to uncheck this and save the Jessi cr2 as a new file. It should also uncompress the obz. Or you can uncompress the files using winzip. There is also a python script that ships with Poser to uncompress all the content files.
Thread: SIGGRAPH passes almost gone | Forum: Animation
Thread: Our New Poser Girl | Forum: MarketPlace Showcase
Thread: Convert V3 clothes to Renda (CC update for Renda) | Forum: MarketPlace Showcase
Thread: How about a Renderosity users convention? | Forum: Community Center
Thread: SoftImage XSI Foundations? | Forum: Poser - OFFICIAL
I've been an XSI user for a while (coming from 3dsmax). >Can it import Poser content? pCharacter Import >Character rigging better than Poser? The rig is more flexible than Poser and the animation tools are in another league. >Impression of render quality and speed? It uses mental ray so the render quality is excellent, but there is definately is a learning curve. Speed depends on your processor's speed. >ease of use It's a complex application so there is a learning curve. If you've used other 3D apps like max, maya, or lightwave then it's easy to learn. -Mark
Thread: Clothes Converter 2.1 now available | Forum: MarketPlace Showcase
Attached Link: http://www.daz3d.com/shop.php?op=itemdetails&item=3139
>What if we bought it here at the Renderosity Marketplace? 1.2 was sold here not 2.0. So you would have to upgrade to 2.0 and then you will have 2.1. The text still says 2.0 but it's 2.1. I have asked Daz to update the text. -MarkThread: fitting David clothing on M3?? and thoughts about Clothes Converter?? | Forum: Poser - OFFICIAL
Attached Link: http://www.cgauction.com/forum/viewtopic.php?t=51
The upcoming update to CC will be able to convert between unimesh characters automatically (details and pictures at the link). You can still tweak or smooth the mesh after the process runs. Hopefully Daz will get it approved soon. I'm also working on new techniques that will be implemented soon. -MarkThread: AutoGroup Editor 1.4 update coming soon | Forum: MarketPlace Showcase
Thread: Autogroup Editor errors order #111002036 | Forum: MarketPlace Customers
