8 threads found!
mdesmarais | 4 | 42 | ||
mdesmarais | 0 | 29 |
(none)
mdesmarais | 0 | 40 |
(none)
mdesmarais | 0 | 50 |
(none)
mdesmarais | 8 | 243 | ||
mdesmarais | 7 | 165 | ||
mdesmarais | 0 | 54 |
(none)
mdesmarais | 7 | 301 |
126 comments found!
I make the tools- you guys make the art! If you make cool images with the shaders, I'd love to have them in my gallery. And/or in the samples section, if you want to share. Markd
Thread: Carrara OSX Intel version? | Forum: Carrara
My user base is waaay smaller than yours, but I stopped doing CS1 and 2 a while ago, and put a note saying to contact me if you want these versions. I've never gotten a request. Markd
Thread: Does anyone know if Shoestring Shaders are C5 ready? | Forum: Carrara
The last glitch I am working on is in SuperMixer Complex- if you choose a smooth blend and have overlapping influence ranges you get a black band. I have a fix, but I'm checking with Eovia to make sure it is the right way to go. Markd
Hi Steama! Seems like filters are swallowing up my email- I've replied twice and they don't seem to be getting through. Shoestring is currently in a beta phase- I hope to get to release very soon (in the next week or so). If you would like to play with the beta version for CS5 (or any other version) you can download here- http://www.des-web.net/html/beta.html Couldn't remember which forum I had seen you on! ;-) Markd
Thread: anything grows plug-in | Forum: Carrara
You just need to drop over to DCG and download the CS4 version- Treat it as a new install, and it will take the same password. take the v3 copy out first. markd
Thread: HELP | Forum: Carrara
With a 1.7 MHz cpu, you could probably run your microwave or MP3 player (maybe). I hope you mean 1.7 GHz. . . ;-) markd
Thread: Source for Hexagon Manual? | Forum: Carrara
On my PC, the .pdf's are located in Program Files/Eovia/Hexagon/data/doc hope that helps markd
Thread: how in carrara make translucence? | Forum: Carrara
You can fake some translucence effects using Lit. . . depends what you are looking for. There are several sample here of different applications. http://www.des-web.net/html/samples.html markd < disclaimer- I am Shoestring Graphics. ;-) >
Thread: Carrara 3D info for After Effects | Forum: Carrara
Anyone know of a public spec for these file formats? A quick search didn't turn up much other than a reference to the MAX sdk. . . Markd
Thread: Translucent flesh | Forum: Carrara
The difficult part of translucency is determining where the object is thick vs thin- the shaders just don't have that kind of info available to them. SSS suffers from a similar issue- when a shader is called, it is called for a single point. You have no access to the points around you (to determine if they should be scattering light into your point). I'm playing with stuff to try and address some of these issues, as is Eric- see his message about the edge shaders which could help control translucency- if you have both, combine it with Lit. markd
Thread: Carrara Activity | Forum: Carrara
If your liver resembles the virgin mary in some way, that might be a good way to raise some cash. ;-) Markd
I like this forum too- I see a few issues that I think prevent it from being the "main" forum- ie getting critical mass. 1) Perception of being Poser-centric 2) Some find the advertising offensive 3) No email option 4) Threads are not marked to indicate new messages 1 and 2 can't easily be changed as they are personal. 3- I'm waiting to see how Ringo pulls this one off. There are still quite a few members at Yahoo that will only be dragged kicking and screamming into the 90's. ;-) Closing the yahoo group might be the only way. 4- This one is a personal peeve. Am I missing something here? I've never found a good way to browse the newest posts. Topics, yes, but not posts. If the traffic were higher, I have a feeling I'd get frustrated.
Thread: 3d masking.... | Forum: Carrara
Hi spinners- Proximity is designed to do exactly what you want. . . this is a sample movie from my site- http://www.des-web.net/mirror_room.mov The only tricky part is that I rotated the scene so that the mirror lays completely in a plane. The file is here- http://www.des-web.net/html/samples.html look about halfway down the page. thanks for the plug Eric! :-) Markd
Thread: Any info on Poser 6 working with Transposer 2? | Forum: Carrara
Thread: Slide Show in Carrara | Forum: Carrara
Offhand, CS isn't really the right app to try and do this. . . However, you could load all your images into textures, apply them to various objects, and run the objects across the screen, or fade them in and out, or fly by them as billboards. . . I've thought about putting 6 images on a cube and rotating it. . . you could also animate a single shader with multiple textures. With a deep tree you could do tons of images. Supermixer would let you do 10 at once. ;-) http://www.des-web.net/html/supermixer.html Good luck, let us know how it turns out! Markd
Thread: Shoestring Shaders update- CS3, CS4, CS5 | Forum: Carrara
