We couldn't find any threads matching the specified search criteria.
11 comments found!
Thread: Poser 11's UI is too small | Forum: Poser - OFFICIAL
A have an other menu-size problem. Yesterday it worked properly, but today the clicked image in the library doesn't appear in larger, it remains invisible small icon! posermenu.JPG
I tried manything, no more idea.
Thread: Exporting from Poser | Forum: DAZ|Studio
I made a 3DSmax scene with ~100 separated objects. If I convert the full scene to .obj, it appears in Poser perfectly, but the parts can't be moved separated. In every other format the scene (after the importing) looks like after the Katrina. FBX, DAE, 3DS ...nothing works normally. I must convert the scene piece by piece (sorry for my poor English)
Thread: Snarlygrbbly's New EZDome in Public Beta!! | Forum: Poser - OFFICIAL
Snarlygribbly posted at 11:03PM Fri, 10 March 2017 - #4298954
No, no update. I asked for people who were willing to help me to fix this to sitemail me here. No-one did, so it isn't getting fixed.
If you can explain what must I do, I'd like to try the debugging version.
I'd run the debugging version, but don't speak in python... :-( At all events thanx for your time!
hborre posted at 9:37AM Sat, 21 January 2017 - #4295577
Did you skip a step? Where is the creation of the dome step? Clicking on either one of the three icons on the left side of the taskbar,..
Step05: clicked on sphere.(third icon). I didn't skip. If I would skip, the background wouldn't be black. And EZinner and EZouter appear. The script can't assign texture for them. If I switch off the original light sources, when I click on Apply everything remain in black, the error message: EZSun not found. What is the EZSun? There isn't in my scene...
I use international Windows, it uses comma to the decimal numbers, not dot. Can it be the error source?
I downloaded the Desert Highway from here: http://hdrlabs.com/sibl/archive.html And I tried the Factory catwalk also, same error...
I have same error. Lights are deleted, ground is invisible, dome created. In the props they are EZInner and EZouter. When I click on Apply it says: EZSun not found.
I click on 'Add sun', I get an error message: File "E:POSEREZDomeezdome.py", line 2875, in AddSun AttributeError: 'NoneType' object has no attribute 'SetLightType' I rename the now created light to EZSun, again Apply: Please check valid dome exists, and everything is black...
