3 threads found!
mgtcs | 15 | 290 | ||
mgtcs | 8 | 272 | ||
mgtcs | 17 | 294 |
32 comments found!
Thread: Extremely Slow Downloads | Forum: Community Center
I agree with Arthur, we have a problem and we need an answer. We'd all hate to see Rod leave indeed so please RR administrators work towards solving this problem!
Thanks
Monica (mgtcs)
Thread: Going For Photorealism | Forum: Poser - OFFICIAL
Thread: How do I make Trans Mat? | Forum: Poser - OFFICIAL
Thread: Props on Poser pro 2012 | Forum: Poser - OFFICIAL
Thank you very much! I will try it! Well, between one RL text and another, I will learn it! :-)
First, I'd like to thank you all for your contributions. I really appreciate the time you all took to answer my question.
Just to clarify, I am a Prime Member here at RR, and have been using Poser for some time now, being really very familiar with it (currently using Poser Pro 2012). I know that, to make props, I must use a 3D modelling program of some sort (UV Mapper, 3D Max, or something), though I am still choosing one to learn how to use properly.
I already know how to import the OBJ file and incorporate it in my props. What I don't know is how to make said incorporated props useable by third parties. This is where a step-by-step tutorial would really be great.
Thank you all once again,
Monica
Thread: Genesis + POSER | Forum: Poser - OFFICIAL
I have downloaded and installed the new plugin that allows Poser to use the (in)famous Genesis character, but it was a dreadful experience.
For starters, there is the very fact that you have to install a plugin in the first place. The only reason that this is so is because Daz wanted to make a play for the market by attempting to lock in their customers into their platform by using proprietary encrypted formats. This, in and of itself, gives you a bad taste before you even start using the damn thing.
Second of all, once I actually installed the plugin, it simply did not work. Instead, it showed a series of error messages saying that other programas were required for the plugin to work and it actually made Poser crash!
Finally, although it was relatively easy to uninstall, it still did leave a lot of crap behind that I had to remove manually. Maybe there is a very complicated way of configuring and setting up the plugin so that it will work, but who needs the hassle?
In a nutshell, I love the Daz characters and products in general, but I am staying away from that plugin altogether, and I recommend everyone else to do the same. I am also avoiding the Genesis line of characters, unless they make it 100% Poser compatible, such as it is the case of Victoria4.
I will post it on my last image at my gallery!
Thread: Cutting Layers | Forum: Photoshop
Hi Elliot
The guys above seem to have just about covered it. Let us know if you managed it.
Monica
Thread: Looking for muzzle flash | Forum: Poser - OFFICIAL
Thread: Looking for Egyptian Sarcophagus | Forum: Poser - OFFICIAL
Maybe this link below helps you!
http://www.turbosquid.com/3d-models/egyptian-sarcophagus-3d-model/311371
Monica
Thread: HELP!!!!! big problem with PSD file!!! | Forum: Photoshop
Cara Ilona
Você já tentou abrir o arquivo em outro programa de imagem? Acho que já!!!
Meu marido não está em casa agora mas pode ter certeza que se tiver solução ele encontra, inclusive o cache do W7, se o problema ainda não tiver sido resolvido entre em contato comigo.
Monica (mgtcs)
Thread: 1930's-40's Tap Pants | Forum: The MarketPlace Wishing Well
Thread: Shadows & Light | Forum: Poser - OFFICIAL
Are you rendering at 300 dpi? If it is only at, say, 72 dpi, I don't think it will show.
Another thing is that you may want to try to use the sidebar controls to reduce the intensity of the red light and to increase the shadows.
Thread: Looking for Train | Forum: Poser - OFFICIAL
