9 threads found!
misha123 | 0 | 116 |
(none)
misha123 | 0 | 76 |
(none)
misha123 | 0 | 102 |
(none)
(none)
misha123 | 2 | 322 | ||
misha123 | 1 | 215 | ||
misha123 | 0 | 24 |
(none)
misha123 | 7 | 231 | ||
misha123 | 2 | 33 |
16 comments found!
Just thinking of an alternative but a cheaper solution may be a programmable joystick. You find many for just under $30 nowadays if you ever feel like experimenting a with it.
Thread: Re-orienting joints | Forum: Carrara
Try locking the children and then rotating the joint so that the local axis (x,y, or z) is in line with orientation of the bones. Then
Thread: AssociatedFX: Driven Available Now! | Forum: Carrara
If you downloaded the zip file before, it may not include the blink_tute.car file for the blink tutorial. If you don't have it, you can download it here.
Michael
AssociatedFX
Thread: Memory Allocation Error in rendering | Forum: Carrara
Thread: camera prob, is this a bug? | Forum: Carrara
Attached Link: http://www.associatedfx.com
If you are using C4 or C5 you can also use my ResetProdFrame plugin to reset the production frame after you have changed it. You can get the free plugin here: http://www.associatedfx.com MikeThread: Plugin Updated | Forum: Carrara
Attached Link: http://www.associatedfx.com/plugins.html
I can only think it must be the Viewpoint media on the pages that may be causing your crashes. I am also using Firefox but with the VMP installed. You may try these alternate pages without the Viewpoint media which can be accessed at: http://www.associatedfx.com/plugins.html Hope that works. MikeThread: Free Plugins for Carrara 5 | Forum: Carrara
I have since fixed some code in CommentPad. If you are using this plugin you may want to update to version 2.95.
Thread: Particle shader question | Forum: Carrara
You can use my pLife plugin shader instead. http://www.associatedfx.com/plugins.html The particle shader with the application does not currently function as you would expect. Mike
Thread: A small personal technical triumph! | Forum: Carrara
Thread: Plug-ins for Carrara | Forum: Carrara
I think I located what might have been the bug. I've posted an update on my site. You should download version 1.6 http://www.associatedfx.com/plugins.html Let me know if you continue to experience the bug. Cheers, Mike
Hi, this is Michael. Can you tell me what might be happening when you try to dupe the file. If possible, perhaps you can post the file and I can take a look at it to see what might be causing the freeze. Mike
Thread: Boolean | Forum: Carrara
You might try exporting the group of objects as OBJ file and reimporting as a single object.
Thread: Modifiers for water | Forum: Carrara
I would use the modifier if animating ripples in a small pond and use a terrain with a dune setting to animating waves in the ocean.
Thread: Has anyone used the Space Navigator with Carrara? | Forum: Carrara
