2 threads found!
myrmadon | 9 | 226 | ||
myrmadon | 7 | 196 |
8 comments found!
I'm not sure the AV is the problem and it will take alot more testing. Things started to go to hell and a hand basket after going from bit defender to Norton. I have an unusual config (running a raid array) and that may be the problem. I'm going back to Bit Defender to see if that corrects the problem. I still cannot get q manager to work with Norton. Q manager ran for one session then stopped so something may be snaggled up in the computer, poser has a bug or the AV is "protecting" me. None of my other programs seem to be acting up. I'll keep testing and posting if there are any suggestions I would appreciate the help.
Thread: Poser Pro 2010 release on the horizon... | Forum: Poser - OFFICIAL
You right...I just don't have 20K. You'd be surprised at the extreme differential in prices. I got Poser 8 for $65 and upgraded to Poser Pro 2010 for $50. I'm retired and Lincoln blinks every time I open my wallet. By waiting a person can save real bucks, however, if you need the program it may be worth 20K. I just added a second monitor and slid all the Poser controls to the second monitor. This second monitor is better than sliced bread.
Good Comments From You
Sorry to bug you. You are quite correct Poser Pro 2010 works quite well for most people. Sometime different computers and different programs have problems. In my case q manager failed completely and support hasn't helped much. After many days of attempts to fix the problem, I' was very frustrated and my post was more of a plea for help.
I think the problem resides with Poser and my anti-virus. Sometimes anti-virus detects valid code that has a virus signature and it deletes that code. I uninstalled Poser Pro 2010 and re- installed it. I also disabled the virus protection program. Since I disabled the firewalls, antivirus, killed the service and start up in msconfig, uninstalled and reinstalled Poser Pro 2010 the assumption is that the problem resided in Poser, and you have to admit early versions of Poser were kind of wonky. As an example, Poser Pro required a collectseneinventory python script for q manager to work properly. I went round and round with support until they came up with that work around.
Last night, I went to a backup that did not have Poser on it or the same virus protection program. This was very time consuming. I reinstalled Poser Pro 2010 (a different anti virus program) and Poser appears to function. I believe the problem resides in the fact that the Poser Pro uninstall does not remove all the registry keys.....Dumb me. If I had manually removed all registry items the reinstall and removed of the offending virus program that should have corrected the problem. (I did manually remove the Poser folder)
The virus program I was using is a popular program and I expect that some other people will be having similar problems. Most people do not feel comfortable tinkering around with the registry. As soon as I sure that this is the problem I will post the conflict. Just be sure that you don't click the "fix" button on any anti-virus program without checking what is going to be "fixed" Also if the q manager fails, know that: 1. This could be caused by a conflict between your anti-virus program and 2. A complete uninstall including registry keys is probably required.
I'm still not completely sure of what's going on and the time it takes to track down a problem is enormous. It may have been just a glitch in the original loading process.
Yes, I would buy Poser 2101, however not at the full $499 price. I think you can get a better deal working the upgrades.
I bought Poser 8 and Poser Pro and for $50 I got Poser Pro 2010. The only problem is Poser Pro 2010 dosen't seem to work. One of the main reasons I wanted Pro is to be able to use the Q manager to batch render several Poser scenes. The only problem is the Q manager dosen't seem to work in Windows 7 64 bit. It just crashes. I've done everything including reloading the program, deleting all the firewalls and virus protection, disabling the startup and services in msconfig, and collect scene inventory. Just darn, the program reminds me of the good old days when Poser would crash and give the message "not responding" I'm of the opinion that I would not spend the big bucks on this program until there is a service release. If you can upgrade for $50 or $70 dollars well it might be worth it. If anyone has suggestions on how to fix this, let me know.
Thread: M4 body subdivisions | Forum: Poser - OFFICIAL
I just bought second skins and am completely at a loss as how to use it. I can make a second skin and get a cr2 file...Now what? I'd like to paint materials on the second skin but the material room isn't working. Nothing happens when I add a material...Do you have to have special jpgs? There are no instructions with the program and I thought I would be able to create interesting clothing, face make up and on and on. Right now I'm extremely disapointed with the program. Any Help would be appreciated.
Thread: Hi Resolution Rendering Info | Forum: Poser - OFFICIAL
Ikendall...I think you hit on one of the problems. To save time I loaded the whole boatload of morphs ++, creature, muscle, RDNA ultimate. I plan to go to Vista 64 and then to Poser Pro the next time they have a sale. Until then I'll just do fewer renders. The renders work the first couple of times. If anyone hears of a sale on Poser Pro, let me know.
Thanks
I have reduced the bucket size, the # of undo's and the # of rendered cache this helps. If you really need a high res render it can be done when the program is first started (before the memory fills) You can make a PZ3 restart the program and make your render. My Poser 7 was always crashing after several hours of rendering and all I'd get was a gray screen (with no render) I was just wondering if it was my OS or motherboard causing this problem and if anyone else out there was having the same problem. (I may have an unstable Abit motherboard and just wanted to know how much of my problems can be attributed to the mother board)
Starting fresh I had no trouble making a 13X19 300 dpi image.
myrmadon
Thread: Vidio Graphic Card Help Needed | Forum: Poser - OFFICIAL
Thanks to all who responded.. I bought a ATI 4670 with with 1 Gig of DDR3. (I had a HD2600) The difference is outstanding. It did help slightly on rendering but the buggest difference is in posing. No longer do the figures jerk when moved. Their motion is smooth. The Poser dials now work without the usual delay. Inserting content is much faster. Apparently my old graphics care was a real bottle neck.
Thanks again
Fred
