4 threads found!
parsnip | 8 | 732 | ||
parsnip | 3 | 131 | ||
parsnip | 6 | 160 | ||
parsnip | 7 | 209 |
7 comments found!
Do you mean inject the various morphs such as thigh thickness/legs length etc? That lets me adjust A4s legs but they still look like A4s legs rather than V4s. I should've mentioned that I'm using poser 7 so I'm not sure if I can do the morph copying thing.
Thread: Is it possible to mix V4 and A4? | Forum: Poser - OFFICIAL
I do have Morph++ but can't see how to use it to achive what I described. Basically what I need is for each body part to have its own set of Aiko 4 sliders rather than one for the whole body.
Thread: Errant toolbar problem. [Poser 7] | Forum: Poser - OFFICIAL
There we go, I knew there had to an option like that hidden somewhere. Problem solved, thanks very much. :)
Thread: Victoria 4 save corruption. | Forum: Poser - OFFICIAL
Figures are RuntimeLibrariesCharacterDAZ People, poses are RuntimeLibrariesPoseDAZ's Victoria 4, geometries are RuntimeGeometriesDAZPeople, which others would be of signifance?
I'm using Vista but had the same problems with XP.
Thanks for the advice, installing various service packs as we speak.
I'm using Poser 7.
External Binary Morph Targets was checked. I've unchecked to see if that helps any.
Aiko 4, Victoria 4 base and Victoria 4.2 cr2s are all in the RuntimeLibrariesCharacterDAZ People folder, pretty sure there's no duplicates.
Not sure what you mean by service packs, but I have Victoria 4.2 Morphs++.
Loading and using the figures is fine, the problems only occur when loading a save file.
Thread: Help regarding the grouping tool. | Forum: Poser - OFFICIAL
Thanks, that's part of the way there. But I still need to be able to rotate, translate, etc each brow individually.
