We couldn't find any threads matching the specified search criteria.
4 comments found!
Thread: Beta testers for Vue 6 plants needed. | Forum: Vue
Thread: Poser/Zbrush/Vue Displacement Maps | Forum: Vue
Hi Bruce,
I don´t tested Displacement Maps in Vue a lot right now, cause there are less to control the Maps. The best way is to go back in Poser and load your Displacement Map that comes from ZBrush in the Material Room in Poser. (don´t forget to Flip the Map first if necessary, and make it as a Greyscale Picture but don´t touch the 16 Bit, it is really important to have a 16 Bit Map) BTW can Vue handle Maps in 16 Bit depth?
But first, don´t forget to make a Note of your Alpha Depth Factor in ZBrush Alpha in the Bottom. For Example the Alpha Depth Factor is 1.234 in ZBrush, in Poser it is 1:10 Type in 0.1234 for the Displacement Map in Poser Material.
A good Place to start is the ZBrush Central Quicklinks, and the Gnomon Workshops of ZBrush Production Pipeline.
I hope this helps, cause meanwhile my Vue 6 is in the trash can, so I can´t make any more tests in Vue6.
Thread: matchmover pro $149 | Forum: Vue
For Privat Use you can find some other Programs like Match Mover. Just do a Search in Google for <Icarus 2.09> or for the first Result will match. Both are Freeware for Privat Use only.
Have fun
pingupongo
Thread: Free...The Curtis Collection Volume 1.... | Forum: Vue
