We couldn't find any threads matching the specified search criteria.
3 comments found!
Thread: Poser 2010 problems on Mac Lion install | Forum: Poser - OFFICIAL
Quote - You will really like Lion then. Apple decided that it’s best if you can’t see your library file. Imagine the shock when I couldn’t see it in my user folder.
This is a bit OT, but there’s a quick workaround for restoring the visibility (and utility) of the user Library in Lion.
Turn on View Path Bar in Finder, then navigate to the user Library using Go | Go to folder | ~/Library.
Once opened drag the Library icon from the path Bar into the Favorites section of the sidebar. Now it’s handy again. :-)
Quote - 1. BEFORE launching your freshly-installed copy of Poser (Debut, Poser 8 or Pro 2010), browse into the root Library/Application Support folder and create a folder for your copy of Poser- 'Poser', 'Poser Pro', or 'Poser Debut'. You'll need to provide an admin password to do this. 2. Launch and serialize Poser normally- you won't be able to see the category icons in the library pane but the mouseover category names should work.
This worked like a charm in a new (downloaded) install of Poser 8 under OSX lion on my MacBook Pro. Thank you, John! -)
Now let the learning curve Begin!
~~ Terry
