6 threads found!
prode | 19 | 312 | ||
prode | 9 | 128 | ||
prode | 17 | 784 | ||
prode | 0 | 109 |
(none)
prode | 3 | 224 | ||
prode | 0 | 57 |
(none)
20 comments found!
hey jedi, check if this may helps you, you have to render at 2k at least; if you have to make an animation you can easily close up the image with hdrshop
cheers
http://www.sharecg.com/v/22879/texture/dosch-city-image
Thread: the shadow catcher and the shadow buffer | Forum: Carrara
allright, I made my tests and finally ordered this easy plugin; very useful indeed. I wish to thank you, Eric and Shonner for your endless patience and willingness. have a good year
ok, that's almost perfect for me shonner! I guess I'm going to give a present to myself; by the way Eric is there any sales promotion or discount at DCG at this time?
I made the comparison with your settings Shonner; it seems to me the blur is not yet perfect, however I'll make my homeworks. thanks
attached test with shadow buffer (1' 38'') and with raytraced shadow (3'33'')
raytraced shadows are sharper and not so realistic with the shadow catcher; shadow buffer works fine; which plugin do you mean? is it free?
Thread: asynchronous background motion | Forum: Carrara
nor the target helper neither the point at modifier did solve the problem; strange background behaviour: I placed the car at axis origin and the skidding remains the same even with the point at function; maybe is related to the camera lens (50 mm) or to the spherical image (the well-known Dosch hdr City). curious to know if anyone had the same animation problem
Thread: HDRI Image blurred | Forum: Carrara
