66 threads found!
pruiz | 11 | 1661 | ||
pruiz | 0 | 137 |
(none)
pruiz | 2 | 122 | ||
pruiz | 30 | 6378 | ||
pruiz | 3 | 145 | ||
pruiz | 9 | 293 | ||
pruiz | 1 | 127 | ||
pruiz | 13 | 177 | ||
pruiz | 7 | 153 | ||
pruiz | 7 | 240 | ||
pruiz | 8 | 128 | ||
pruiz | 7 | 105 | ||
pruiz | 2 | 105 | ||
pruiz | 7 | 175 | ||
pruiz | 4 | 110 |
174 comments found!
No it just opens 'normally'. So I guess my serial number took. I downloaded this from the Smith Micro site - but there is another Beta version in the content repositary. Is it different and should I install that? Thanks for your help.
structure posted at 1:04PM Sat, 16 November 2019 - #4370349
Hey Pruiz, when you open poser - does it have a registration screen with a trial version button before it starts?
Thread: Poser 11 and Poser 2012 Pro Licenses lost? | Forum: Poser - OFFICIAL
Thanks, structure - I did that and connected to the license server and used one of my serial numbers - but I am not sure that it isn't just a validated trial and will lock me out again.
I have 2 desktops Intel i7 8 core - Gtx 960 - Win 10 pro. P11 on one now uninstalled with geek (thanks for this tip) - now what do I do.
I have P2012 Pro which still runs on one - I want to get P11.2 and use my Smith Micro serial. How do I proceed.
structure posted at 11:41AM Fri, 15 November 2019 - #4370281
uninstall poser, using geek uninstaller ( or the mac equivalent )- then reinstall - that should cure what ails ya.
It also helps if you give us a little more detail, Our knowing your Operating System is a necessity in order to more readily assist you.
I have now P11 (11.2 I think) installed and when I try to open I get 'Grace period for activating has expired' - I insert the serial number(s) from previous Smith Micro versions and every time get 'Serial number and previous Serial number invalid' I have proof of serial numbers for versions but all seem blocked. Is there any way aroound this?
Thread: Poser Dyn clothing now in Daz Studio | Forum: DAZ|Studio
Thank you Boudicca36. Does anyone know where the "full Optitex plugin" - paid version may be obtained?
kaotkbliss posted at 6:11PM Wed, 29 June 2016 - #4272245
Lola just released an update to her script which seems to work again in the latest Daz :) I was able to convert a couple of conforming outfits so far, but Nerd 3D's free Michael/Freak poser dynamic loin cloth would not convert.
I have 2 versions running 4.9.2.70 and the Beta Public build 4.9.3.25 - just updated because the previous version crashed and disappeared - I only use the original Dyncreator script (BTW where does one obtain updates for Dyncraetor?) So the 4.9.2 version works fine with Dyncreator converting Marvellous Designer .obj's but the Public build version just will not "see"' Dyncreator clothing. I even tried deleting the plugins in the public build and copiying in the plugin version from the 4.9.2 .70 build - nothing shows in Dynamic Cloth!!
Any ideas welcomed.
Thread: LIBRARY IS TOTALLY BROKEN IN POSER !! | Forum: Poser - OFFICIAL
I tried external libraries and reverting to adobe air on 2014 but thought that the SR1 would fix the library - still totally locked up. Is no one using Poser 11 - I cannot imagine that anyone could put up with a non functioning vital feature dare I say utility. I will go on a search again for an external library approach - but what gives here?
Thread: Dynamic hair fly off | Forum: Poser - OFFICIAL
RedPhantom posted at 10:58AM Sat, 19 December 2015 - #4244948
This seems to be a bug. There are others who've had it too. Preta-3d knows about it. Hopefully they can fix it.
I actually see a sort of flash/waiver in the preview window as Reality opens. I'll post this to the Reality forum too.
Thanks for the help from many. Answer for me was to just set up external chrome based library. I'm somewhat bemused by SM who can put out a product that isn't plug n play and just shrug it off.
I only use Poser now for Dynamic hair and cloth - DS for all else - so this dislocation is really painful. I can't progress projects at all.
The site support site is equally broken. They only register the ticket and wait 10 days and close it out. Now they are upgrading the site and I cannot get in.
Thread: Poser 11/Poser 11 Pro: Bug Reports | Forum: Poser - OFFICIAL
3photog posted at 10:10PM Wed, 16 December 2015 - #4244230
I am sorry I upgraded to Poser Pro 11 so soon. I can't tell you what problems I might have because I can't get the Library to load more than one or two items before it shows no content. I think I have discovered that if I load one or two content items and save the file, usually I can reopen it and add one or two more items. Not very helpful. Between Windows 10 problems (finally solved) and Poser problems, my image making has been seriously curtailed.
I am completely at a loss with Library too - I really cannot get any response - same issues as in quote. I cannot get any constructive work done. I need to revert to Game developer - this library function just does not work. I have messed with IE version installs etc. NOTHING!! As usual no response trfom Smith Micro.
Thread: EZSkin definition for Dawn?? | Forum: Poser - OFFICIAL
Thanks Snarly. I will report any problem but asume all is fixed. Thanks again for the great stuff you make available. David Keene.
Quote - > Quote - I'm not saying that mine is any better than what others have done, by the way :-)
Texture Transformer > When trying to run Ezskin with Dawn and simple converted V4texture using Texture converter - Script error reads - "Unknown Input (transparancy) in node type poserĀ
"Traceback (most recent call last):
File "L:Poser developmentEZSkin+EZSkin+.py", line 2864, in Apply
File "L:Poser developmentEZSkin+EZSkin+.py", line 4196, in MakeSpecularOnly
AttributeError: 'NoneType' object has no attribute 'SetFloat'"Snarly - any ideas what is causing this?
Also I'd add:
If I use the Dawn base texture with EzSkin (using the latest version and Dawn definition - I don't get this error. I have tried turning off all transpany settings in the converted materials before running Ezskin but error persists. It must be something Texture converter is doing that Ezskin doesn't like.
