1 threads found!
rheater | 1 | 4 |
7 comments found!
Very nice but lose the lens flare or rotate it. A real lens flare changes angles as the light sorce moves across the camera lens. Otherwise very fine work. Russ
Thread: What I hope is a simple question... | Forum: Animation
Oops it made the button instead of showing the html. Let me try again. (FORM)(INPUT TYPE=BUTTON VALUE="BACK" onClick="history.back(-1)")(/FORM) Substitute the less than and greater than symbols for the open and close parenthaces except before and after the -1. Russ PS; If thats clear as mud let me know I'll try again.
Here is a short java script I found for going back, I don't know if it will help. Don't know about going to next picture. Russ
Thread: Networking? Mac to PC | Forum: Poser - OFFICIAL
http://www.thursby.com/products/dave.htm and another one http://www.miramarsys.com/products/pcmaclan72.htm Russ
Thread: Networking ? Mac to PC | Forum: Bryce
Should be doable. Check http://www.farallon.com/dr.farallon/mac/mac_pc_ether.html or http://machardware.about.com/compute/machardware/library/weekly/aa050799.htm Russ
Thread: Altitude Rendering | Forum: Bryce
Try this. Works in directors view only. First delete the ground plane, then turn off underground. Next drag the track ball, to change your angle of view untill the clouds/sky is at the bottom of your view (upsidedown). Then play with different skys. This keep a horizon but makes it apear that your above the cloud plain. You'll get some strange effects with some skys and the sun will apear to be above the horizon with some views, you can play with that also. Have fun! Russ
Thread: TUTORIALS FOR LAYERS NEEDED | Forum: Photoshop
http://www.adobe.com./products/tips/photoshop.html There are serveral good tutorials here. Russ
Thread: Sunrise animation | Forum: Bryce
