10 threads found!
robs | 1 | 40 | ||
robs | 3 | 70 | ||
robs | 5 | 27 | ||
robs | 5 | 23 | ||
robs | 2 | 11 | ||
robs | 3 | 17 |
2000 Dec 02 11:33 AM
robs | 3 | 20 | ||
robs | 1 | 8 | ||
robs | 0 | 3 |
(none)
robs | 6 | 22 |
6 comments found!
Thread: character window stuck in upper left | Forum: Poser - OFFICIAL
Ah, I had set Launch to Factory State but not Use Factory State With both set a restart fixed the problem. Thanks all. Rob
Thread: ProPack Problem (revised) | Forum: Poser - OFFICIAL
Curious Labs tech support came through ;-) After several emails back and forth (quick response from CL support :-) the problem turned out to be extranous files left from previous version(s) of Poser. The fix was: 1. de-install Poser 2. delete entire directory tree 3. re-install Poser 4 (plain without any patches) 4. re-install ProPack Rob
Thread: Dual head problem | Forum: Poser - OFFICIAL
Thread: Animation bulk change | Forum: Poser - OFFICIAL
In the graph window I can select all the frames but when I try to move up or down, all un-select except the one the mouse is nearest. I have tried 'control', 'shift', etc, but cannot get more than one key to move at a time. I'll try the neck tilt. It sure would be nice to be able to select and move a bunch of key frames en-mass ;-) Rob
Thread: python export image? | Forum: Poser - OFFICIAL
