8 threads found!
rolffimages | 7 | 701 | ||
rolffimages | 9 | 614 | ||
rolffimages | 2 | 453 | ||
rolffimages | 2 | 120 | ||
rolffimages | 6 | 384 | ||
rolffimages | 3 | 308 | ||
rolffimages | 5 | 262 | ||
rolffimages | 11 | 567 |
12 comments found!
Thank you everybody! I am not super familiar with daz but I ended up doing it in daz. Now I have to figure out how to change textures in Daz. If anyone has any tips on textures in daz Id appreciate it. Thank you all so much for your help!
Thread: JOB! Need simple cloak for poser figure | Forum: Poser - OFFICIAL
Yeah So for whatever reason it is not working. I suspect it is too old a model and I have the latest version of poser.Something like this?
https://www.renderosity.com/rr/mod/bcs/sshodans-cloaks-m4/84680/
Or see the Dynamic Fantasy Robe for V4 and M4 at DAZ.
Dynamic clothing is pretty easy to use with any figure, and with something like a cloak, the results will be much better with dynamic clothing.
I think that will be perfect! Thank you!Something like this?
Thread: HELP! Animating text across several objects | Forum: Vue
Thanks for your reply. I will see what I can do. I'm not super familiar with using nodes but perhaps I can figure it out. Thanks.
Thread: Recommends on setup of pcs for rendering | Forum: Vue
Let me add this little bit. What i am seeking recommends for is how would you set these up for network renders? Which would you use as the main PC and which would be the render cows.
Thread: How to create shallow depth of field in vue | Forum: Vue
Thread: Way to align a lunar map on a sphere so viewer sees near side of moon | Forum: Vue
Thank you Ironsoul. I am not referring to the planets option inside vue. I am instead referring to a map of the moon wrapped on a sphere. I am using it as an object and it will not be in the sky but instead used as multiple objects on the ground. I am thinking there is perhaps some way other than just trying to do it visually. Perhaps a formula of some kind???
Thread: Anyone know if this is possible and if so how to do it? | Forum: Poser - OFFICIAL
The sphere over the face sounds like it might work. I will have to try that. Thank you both for your feedback! Will try this and be back if this does not work. It does sound hopeful though. Thanks so much!
Hmm, any other ideas? I tried using the morph tools in poser. Not really getting the effect I want. Is there a way to actually replace the face?? I could do the effect in PS but I am trying to avoid that. .Id like to be able to manipulate the figure in poser. I've seen figures with smooth surfaces where the face should be so there must be a way to do it. I would purchase a figure if there was one with the look I am going for. However I have not seen any as of yet.
Thread: Amazon Elastic Compute Cloud for render farm? | Forum: Vue
You need vue on the machine you are rendering from and you need only the render cow on the additional machines
