5 threads found!
salmonfisher | 18 | 390 | ||
salmonfisher | 2 | 58 | ||
salmonfisher | 10 | 260 | ||
salmonfisher | 20 | 229 | ||
salmonfisher | 14 | 269 |
21 comments found!
edit i found it by seaching through google: http://www.runtimedna.com/ArtMaterials/
I just can not afford it.
god i hate being unemployed anyway i saved the pyton script.
I will just have to manage with the toon shaders i got with poser 8.
Thanks everyone for your help
issue closed
Thread: toon shading | Forum: Poser - OFFICIAL
Thanks winterclaw just wanted to be sure before i tried doing it.
Is there such a thing as a body suit toon style ?
newbee question: how can i select the whole body and apply a shader effect.
I am having loads of fun trying out these effects.
Thanks
Hi winterclaw so i have renamed the file to .mtl.
Can i copy it and paste it into the folder poser runtime - library - materials ?
Thanks also 3dvice i have poser 8 so i found the sixus1 >toon as well.
I also did a seach within renderosity toon free stuff I should have done this like ages ago, theres so much stuff.
I watched the quick tutorial on how to apply toon render: select body hold shift apply toon render i also did this to hair and clothing, it will be intresting to see if there is a improvement by using a toon shader.
Thread: items required for m4 | Forum: Poser - OFFICIAL
Quote - ...there's a free bowtie here http://www.sharecg.com/v/28531/poser/Bowtie-for-Freak - it's for the freak, but I'm sure it'll work for M4 with a little scalling down and repositioning.
i can not get this bowtie to instail i have tried instail from zip from within poser 8 normaly works but the "tentman" does not show.
i tried extracting to poser 8 content same thing.
i tried drag into daz studio content folder same thing.
im sure the file is instailed but i can not locate it even if i seach "bow tie" search "tentman"
help?
Thread: need help with a breathing animated pose for m4 | Forum: Poser - OFFICIAL
thanks but no luck.
how do i zero my figure in poser as i cannot get the bluethooth earpiece to fit the model?
when i load the model it asumed the default position and i am unsure how to select the zero pose position.
thanks i got them both sad that the link to the agent ear piece is not working could have been exactly what i needed.
ok in the readme file is this zero your figures pose before applying im unsure what i have to do.
is there any way renderosity could help with fixing this dowload : http://www.renderosity.com/mod/freestuff/index.php?user_id=20054 as i would realy like to have this one??????????????
Thread: gore-dom | Forum: Poser Python Scripting
thanks for all the help but i would be better off adding the blood textures myself obiviously not in poser but in my graphic sofware it will be more time consuming but possible.
i am sorry i bought this i will get on to vendor for a refund.
sorry for the late reply i have followed your advice markschum but it seems i can only see the result when i render the jacket so i wont be able to use this product as i will be saving as images and not rendering first.
Any advice?
thanks i appricate nothing is wrong with the preview.
lets get things of to a good start first i am a newbee to poser.
with this acu jacket there are only materials for specific items i.e capt / serg / cap and so forth there is not one for the entire jacket.
i need to begin at this stage how do i get the jacket into the material room im not sure even if this is right but it seems right.
send the jacket to material room as normal.
apply the effect to the jacket in the material room.
As i said i am a newbee
but i only see the result I.e the blood effect when i render.
lets go ack to the beginning and explane from there please.
first i load the jacket what next?
