1 threads found!
sixgunsloaded | 9 | 453 |
5 comments found!
RedPhantom posted at 7:40 AM Fri, 1 March 2024 - #4482105
Yeah, I can't get either one of those to work for me with Superfly. Simply importing it works perfectly if I use Firefly but as soon as I try Superfly, something just goes wrong.I don't use background images often but I do remember sometimes having issues if I tried to set up a background in the material room like you would for adding a texture to a prop. If You used file>import>background picture, it worked. I don't know how or why. I never looked into it further.
I have a sort-of workaround by attaching the bg image to a flat-plane primitive and resizing and positioning it in the scene but it's a pain in the butt to try to do it that way and it complicates the lighting.
Thread: Problem using background images in Superfly | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Check the "auto-fit" in the background picture node in material room.
Firstly, thank you for the suggestion.
I tried this today exactly as indicated, but it didn't work. Actually, to clarify - it worked one time. lol After that it was no joy. I couldn't get it to work again no matter what I did.
In fact, it also did something else I don't understand. After I'd import the background and click auto-fit and connect the nodes as shown, if I then tried to switch back to the pose room, it would undo everything, including clearing the background.
So I'm right back at square-one. :(
hborre posted at 6:38 PM Mon, 26 February 2024 - #4481994
I have run several renders for Superfly and Firefly with a few background scenes and have not noticed any irregularities between them. If this was a straightforward problem, I would see it immediately, regardless of the dimensions of the images.
Oh sorry, yeah it's 1920x1080. And that's the size I almost always use and almost always render my final images at as well. I just prefer it because it fits perfectly on HDTVs.
Thread: Incentives/Discounts | Forum: MarketPlace Customers
I agree with the sentiments being stated here, for what it's worth. I was very disappointed to discover my last purchase earned no rewards points (I'm not a Prime customer and don't feel it's worth the cost) and I think taking them away from regular customers is a very bad idea. It's already put me off buying a few things. I sincerely hope Rendo changes their mind about it.
