We couldn't find any threads matching the specified search criteria.
1 comments found!
Are you wanting to create a morph for poser? I dont know if I am understanding your question. Here is what I would do, ipmport the file as .obj then open it in the vertex modeler and use the wireframe setting to move vertices. You may want to select part of the mesh and use the hide command and set the the handel size to medium or small. Also you have to scale the model up to 1000% or so. Hope this helps.
Message edited on: 05/19/2004 18:41
Thread: tough one: a wire frame hand... | Forum: Carrara
